Think I'm running rich ...
Old Mar 23, 2006 | 08:47 PM
tl hatch's Avatar
Default Think I'm running rich ...
Let's start with what I DO know:
<U>93 EG Si</U>
'94 JDM B18C
JDM DC 4-1 Header
Racing Sports Akimoto intake w/AEM filter
skunk2 IM
CTR Cams
AEM adjustable gears 0/0 (for now)
Magnaflow CAT/Resonator/muffler, all new
Stock injectors
Stock FPR
Stock P72 ECU
Denso Iridium plugs
New cap,rotor,wires
New thermostat,ECT sensor and sending unit
New O2 sensor
Bad IACV (hunts for idle when warm, normal when top IACV hole is plugged,just cleaned it)
Used Seafoam about 500 miles ago, have since changed oil.
<U>What I'm noticing:</U>
-Carbon from the exhaust. Maybe normal but seems excessive, possible residue of seafoam cleansing?
-Exhaust popping when shifting. Not backfiring, but not the normal "you've just got better flow" popping. Also happens when the idle is surging. Because of IACV?
-Distributor appears to be almost fully advanced (smog station reports timing at 14degrees, I see it at 16degrees).
Where should I start?
Old Mar 23, 2006 | 09:25 PM
Tad's Avatar
Tad
um first of all use a timing gun and make sure ur ign. timing is correct..
Old Mar 23, 2006 | 10:30 PM
tl hatch's Avatar
Default Re: (Tad)
I set it at 16 a couple days ago, before the smog station looked at it and said it was 14. I'll check it again.
Old Mar 24, 2006 | 09:18 AM
tl hatch's Avatar
Default Re: (jklobo)
bump it
Old Mar 25, 2006 | 01:22 PM
tl hatch's Avatar
Timing belt is tensioned as of last night, and ignition timing is at 16deg (red mark on pulley).
Old Mar 27, 2006 | 09:14 AM
tl hatch's Avatar
So I'm getting carbon spraying from my exhaust when I start the car up, there's more of it when it's cold. There's no fuel in the exhaust because it doesn't light when I put a lighter to it while on a piece of cardboard. The liquid is definitely water, not a lot, but there is a little water which I've read is normal.
Should I not be running iridium plugs? Is that making combustion temps too hot? If so which plugs are best for my motor and which heat rating and gap is best?
Old Mar 27, 2006 | 03:38 PM
tl hatch's Avatar
anyone?
Old Mar 28, 2006 | 09:19 PM
tl hatch's Avatar
no one has any ideas?
Old Mar 28, 2006 | 09:34 PM
Tad's Avatar
Tad
carbon/moisture out the tailpipe is normal
good excuse to get that bitch tuned if ur worried about ur a/f
Old Mar 28, 2006 | 11:16 PM
tl hatch's Avatar
Default Re: (Tad)
Yeah, tuning is on the to-do list. Probably in the next couple months, it gets driven only a couple days a week.
Should I steer away from iridium plugs anyway?
Old Mar 28, 2006 | 11:18 PM
Tad's Avatar
Tad
yeah they're a waste of money
the standard ngk stuff is fine,
thats wut EVERYONE uses,
including the crazy high hp folk
Old Mar 29, 2006 | 05:16 AM
hatchonarun's Avatar
Default Re: (Tad)
how bad is it smokin if its really alot it may be your pcv valve cuz i had a problem with it and my car was running rich as hell and smokin so try that.....
vmoua509
Aug 28, 2017 09:13 AM
Bravenrace
Dec 3, 2010 11:34 PM
drvfast
Engine Management and Tuning
May 27, 2010 09:31 PM
ftrms
Apr 14, 2010 05:58 PM
s_vares
13
Jan 4, 2006 06:23 AM
