thin headgasket?
Old May 1, 2005 | 10:47 AM
hybridvtecef's Avatar
Default thin headgasket?
just did a thin headgasket on my b16a. it has 25 over ctr pistons. now it has a little tick not to loud but not queit could this be caused by no clearance between the pistons and valves??
Old May 1, 2005 | 11:12 AM
mmuller's Avatar
Mad Scientist
Default Re: thin headgasket? (hybridvtecef)
tick? describe better... does it sound like you have marbles inside your engine?
and what cams are you running that you think you need more than 11.8 compression?
Old May 1, 2005 | 11:19 AM
Default Re: thin headgasket? (mmuller)
yea sounds like a marbles not like pinging though sounds like the valves are clearing but im sure. when i turn the motor over by hand it doesnt bind at all it turns smooth. i have stock cams
Old May 1, 2005 | 03:28 PM
NJIN BUILDR's Avatar
With ctr pistons you may not have enough piston to head clearance.You need around .035".That is the gasket clearance plus the piston to deck height (or minus if the piston is above the deck).With ctr pistons you may have close to a zero deck.With stock cams its probably not valve to piston.You probably have to much compression for pump fuel also.
Glenn
Old May 1, 2005 | 08:54 PM
Kendall's Avatar
How thick of a headgasket did you install? And no it won't be valve clearance issues, but there could be head clearance issues as NJIN BUILDR said.
Old May 1, 2005 | 10:25 PM
Default Re: (Kendall)
cool guys thanks alot. i have just decided to go with stock headgasket nothing better than OEM!
Chance EG
Apr 6, 2020 11:27 AM
andrewafdf
16
Apr 8, 2009 12:56 AM
Rheg6
16
Feb 16, 2009 07:17 PM
paeaknoy
Apr 11, 2004 03:32 PM
Darkteg
11
Aug 31, 2002 12:45 PM
