Are these cams fixable?
Old Jan 13, 2006 | 05:34 PM
crxh22project's Avatar
Default Are these cams fixable?
I got some Gsr cams with some cam gears, the cams have rough demage from the cam caps being too tight here are some pics, are they worth fixing.. I plan on using them on my b16a. Only the intake one has the most demage.
Old Jan 13, 2006 | 05:37 PM
mmuller's Avatar
Mad Scientist
Default Re: Are these cams fixable? (crxh22project)
we can barely see the picture..
Old Jan 13, 2006 | 05:39 PM
Default Re: Are these cams fixable? (mmuller)
Im learning...
Old Jan 13, 2006 | 05:44 PM
Jim Truett's Avatar
That looks like aluminum has been galled onto the surfaces. A micropolish should clean them up fine.
Old Jan 13, 2006 | 05:55 PM
Default Re: Are these cams fixable? (Jim Truett)
a micro polish can fix them will they fit fine on my b16?? Doesn't that remove material?
Old Jan 13, 2006 | 05:57 PM
you can feel some rough lines thought can It still be fixed>??
who can fix these for me
Old Jan 13, 2006 | 08:24 PM
flatblack crx's Avatar
let me ask my boy he might just give you his if you pay shipping
Old Jan 14, 2006 | 12:37 PM
Scott_Tucker's Avatar
If the bearing journals are scored you can have them built up by welding and re-ground. The lobes are OK right?
Old Jan 16, 2006 | 02:47 PM
Default Re: Are these cams fixable? (AutoEng2002Si)
yes
Old Jan 16, 2006 | 04:38 PM
EnzoSpeed's Avatar
Micro-polishing does NOT remove material. It will not make those look any better.
Old Jan 16, 2006 | 06:58 PM
Default Re: Are these cams fixable? (EnzoSpeed)
So are these cams worth the micro polish?
Old Jan 16, 2006 | 07:46 PM
Runnerdown's Avatar
They are only gsr cams. Don't put them in a perfectly good head and risk damage. Micro polish is for crank journals final finish not removing galled up aluminum and scratches
Old Jan 16, 2006 | 08:11 PM
B16CRXT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoEng2002Si &raquo;</TD></TR><TR><TD CLASS="quote">If the bearing journals are scored you can have them built up by welding and re-ground. The lobes are OK right?</TD></TR></TABLE>
This is your only option. But its more expensive than its worth. Buy another set of GSR cams. These are worthless, unless you have a good hookup to get the regrind done.
Old Jan 16, 2006 | 09:24 PM
Default Re: Are these cams fixable? (B16CRXT)
normally what is the cost to regrind them
Old Jan 18, 2006 | 04:36 PM
Well i took them to get cleaned up and there is still some scratches lines a little rough I decided not a to risk my head
Old Jan 18, 2006 | 04:52 PM
Runnerdown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxh22project &raquo;</TD></TR><TR><TD CLASS="quote">Well i took them to get cleaned up and there is still some scratches lines a little rough I decided not a to risk my head</TD></TR></TABLE>
Good move
Old Jan 18, 2006 | 09:36 PM
Default Re: Are these cams fixable? (Runnerdown)
I dont know man they are smooth but you can feel lines, the machinist said it should be ok he said those lines will help it oil better. Yay or Nah?
I really dont have money for some real cams right now.
Old Jan 18, 2006 | 11:44 PM
EnzoSpeed's Avatar
Cams are pretty forgiving when it comes to journal damage. I'd use those, but it's just me. The cam I'm running now has some grooves, but it's not as bad as the one in the above pics.
Old Jan 19, 2006 | 08:21 AM
im gonna install them, and see what happens
Old Jan 19, 2006 | 11:00 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxh22project &raquo;</TD></TR><TR><TD CLASS="quote">im gonna install them, and see what happens</TD></TR></TABLE>
With the price of undamaged GS-R cams being so low, why risk running these?
Old Jan 19, 2006 | 03:57 PM
EnzoSpeed's Avatar
Default Re: Are these cams fixable? (Padawan)
Really, what's the risk? It's not going to sieze because of the grooves.
Old Jan 19, 2006 | 04:22 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Really, what's the risk? It's not going to sieze because of the grooves. </TD></TR></TABLE>
Not necessarily, no. However, if the remaining damage on the cams is sufficient, it could in turn cause damage to journals. With undamaged GS-R cams being available for less than $100, why chance using the damaged ones?
JDM B20 EH2
Dec 10, 2012 06:18 PM
BDogggUT34
May 20, 2011 07:34 AM
tempsohc
Nov 12, 2006 10:29 PM
camp1320.com
Dec 3, 2002 08:53 PM
d-wreck
12
Dec 29, 2001 08:01 PM
