Car temp gauge goes up when going into boost?
Old 03-21-2014, 03:24 PM
Kid-jdm-teggy's Avatar
Default Car temp gauge goes up when going into boost?
Ok now my car is acting up again. The temp gauge stays perfectly where its suppose to be at idle and while cruising. But when i go into boost, say over 3 psi, the temp gauge goes up to 3/4 and then it starts to cool back down when im driving in a vacuum. Heater works so water pump is good. Only coolant leak is from the reservoir lid being fill up from the heat of the engine when it climbed to 3/4 temp. Could a bad thermostat be the culprit? What else can it be? Rad fan turns on.
1993 civic
D16z6
16psi
Old 03-21-2014, 03:30 PM
Andy8's Avatar
Head lift from sound of it. Do you have arp head studs?
Old 03-21-2014, 03:38 PM
Default Re: Car temp gauge goes up when going into boost?
Yes, if it was head lift, wouldnt there be white smoke coming out of the exhaust or coolant in the oil? Cause mine isnt doing any of it.
Old 03-21-2014, 04:35 PM
KevinEF7's Avatar
No it doesnt need to do either of those, pushing coolant into the overflow only after boosting is an almost sure sign of headlift, especially on a sohc
Take the VC off and TQ them headbolts down again, try and save it!
Old 03-21-2014, 04:40 PM
DAMN IT!! Could it be a blown hg cause im about to go borrow my friends compression gauge and see
Old 03-21-2014, 04:58 PM
Keyboard Humorist
4drEF's Avatar
What brand hg did you use?
Old 03-21-2014, 05:16 PM
New Oem one, probably wasnt the best choice huh? I pulled my rad cap off and filled it up and no bubbles were coming up until i give it a little rev. Blown?
Old 03-21-2014, 06:00 PM
TravisBiggie's Avatar
oem is the best way to go... Ive used numerous 20$ ebay MLS headgaskets on 400whp with no issues..
Old 03-21-2014, 06:06 PM
Well when I filled the radiator back up with coolant, it took the whole reservoir cause i dump the overflowed fluid back in. I assume the increase in temp was from little fluid from the radiator cause there was just enough coolant to fill the radiator back up... So i think its a bad radiator cap??
Old 03-21-2014, 06:11 PM
Turbo-LS's Avatar
It could be a multitude of things. Head lift head gasket bad thermostat airbound system just to start. Is it tuned? Who tuned it? What's the setup?
Old 03-21-2014, 06:23 PM
Ok, just tested it again. Radiator bubbles once every 5 seconds, but when i turn on the heat it stopped completely even when i revved it. So what the hell? And yes its tuned. Street tuned by John Vega at Phearable.
Old 03-21-2014, 06:27 PM
As far as setup,
t3/t4 .48 .62
Oem hg
9.0:1 srp pistons with srp rings
Arp headstud
Adept rods with arp rod bolts
560cc dsm
Walbro 255
Old 03-21-2014, 06:29 PM
Radiator was 2 months old (skunk2 alpha series). Could a bad radiator cap do this?
Old 03-21-2014, 06:30 PM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
If it bubbles every so often in the reservoir it is almost surely a blown headgasket or something is cracked. I highly recommend a leak-down test and compression test. A bad radiator cap won't cause bubbles.
Old 03-21-2014, 06:44 PM
come back when you compression test it.
Old 03-21-2014, 06:55 PM
Ok i will do it tomorrow when i rent one from autozone. I hope its just a blown hg, dont want a cracked head or sleeve
Old 03-21-2014, 07:10 PM
KevinEF7's Avatar
Sounds like your not doing any sort of proper bleeding. You cant just fill the rad full after pushing so much coolant and losing it through the overflow, once air gets pulled into the system it can cause all sorts of headaches
Do a good coolant bleed, idle the car with the rad cap off, cabin heat to full hot, top off the radiator until the lower hose gets hot and the rad fan comes on, cap the rad, top off the overflow resevoir (even fill it a half inch above max at this point). Turn the car off and let it cool. The car will probably suck in some from the overflow.
Air in your system can cause weird overflow problems, its so easy to do this procedure you may aswell rule it out, sorry if I get the impression that your not giving it a good air bleed, but it would certainly cause some issues if air was trapped
If you do have ARP headstuds, verifying they are torqued would be a good step at this point to before tearing anything apart, check all 10 in proper sequence, only takes 15 min, they do back off in some instances. I personally TQ with arp lube and do 5ft/lbs above what arp recomends
Old 03-22-2014, 08:32 AM
Cyl 1= 107psi, Cyl 2= 178psi, Cyl 3= 180psi, Cyl 4= 170psi. Cyl 1 is the one that has the wastegate placed on top of its runner, so i believe that could have done some damage to the valves?
Old 03-22-2014, 08:34 AM
Old 03-22-2014, 08:36 AM
Ok i did what you told me about the cabin heat being on and let it idle till warm, now theres no bubbles while idling or when revving. But now my compression is really low
Old 03-22-2014, 08:38 AM
Pour a little bit of motor oil in cyl 1 and compression went up to 120psi
Old 03-22-2014, 09:47 AM
Pour oil into the cyl 3 and it went from 180 to 191 so i assume that cyl 1 has a burnt valve. Also cyl 1 was the only one with the spark plug with a black color, the other 3 had a white color
Old 03-22-2014, 11:17 AM
KevinEF7's Avatar
Man your diagnosis is all over the map.
Cyl # 1 bumped 10psi with a spoon of oil, then you tried Cyl #3 with a spoon of oil and it also bumped 10psi. That means Cyl #1 has a burnt valve?? but #3 is fine....
TQ your headstuds
Old 03-22-2014, 11:21 AM
KevinEF7's Avatar
And just at a glance of your picture. Whats going on with your vacuum line for the MBC you have on the back right of the valve cover?? It looks like you have your BOV and wastegate feeding the MBC, neither getting a vacuum/boost source ....
Old 03-22-2014, 12:14 PM
I dont get what you are trying to say. And for the compression, what do you think? Could improper torque of the headstud cause the lost of 60psi of compression?
Quick Reply: Car temp gauge goes up when going into boost?
