tensioner bolt stuck!!!
Old Jan 13, 2009 | 08:40 AM
The Up Garage's Avatar
Default tensioner bolt stuck!!!
i put on my b16 head on my gsr block and when i was putting on the timing belt i tried to loosen the tensioner bolt and it was stuck it wont loosen or tighten i loosened it when i removed the old head and it was ok but now it just doesnt move!!!...LMK what u think ....thanks
Old Jan 13, 2009 | 09:26 AM
sackdz's Avatar
Default Re: tensioner bolt stuck!!!
Uhhh... try harder. Use a 6-pt socket and a breaker bar. It's not one you want to strip, either.
Old Jan 15, 2009 | 07:26 PM
still have the problem any other suggestions???
Old Jan 16, 2009 | 05:06 PM
jaysalti's Avatar
best bet is to get the belts off, the power steering out of the way, and then find the longest handle wratchet or wrench you can. I had to use a breaker bar with mine. use a six sided socket. if it strips, use the irwin bolt grip. torque wrench it on to verify that it is set properly @ 40 ft/lbs.
good luck!
qpzm12
May 7, 2011 10:00 PM
stevew84
Mar 7, 2009 07:36 AM
seeeya04
Nov 24, 2005 03:25 PM
gwolf
Sep 4, 2005 04:33 AM
Btothe3rdDegree
May 15, 2003 10:32 PM
