Temp gauge not reading...what to check?
Old Sep 24, 2003 | 02:53 PM
TurboJesse
Guest
Posts: n/a
Default Temp gauge not reading...what to check?
My temp gauge does not seem to be reading anything, i start the car up and let it idle for ~5 mins and it doesn't do anything...what should i check? thank you
Old Sep 24, 2003 | 02:56 PM
pro1342's Avatar
Default Re: Temp gauge not reading...what to check? (Mpir3)
There is a single wire sensor on the side of the head under the distributor....that is probably your problem. If you replace it, and the wiring is good, but the gauge still does not read, the gauge is bad.
Old Sep 24, 2003 | 03:03 PM
BuddhaSiR's Avatar
Default Re: Temp gauge not reading...what to check? (pro1342)
ground that wire that he is talking about and see what your temp gauge does. It should sweep pass hot on your gauge. that'll tell you if your gauge is functioning. probably have a bad temp sensor.
Old Sep 25, 2003 | 04:15 AM
JimBlake's Avatar
Default Re: Temp gauge not reading...what to check? (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">ground that wire that he is talking about and see what your temp gauge does. It should sweep pass hot on your gauge. that'll tell you if your gauge is functioning. probably have a bad temp sensor.</TD></TR></TABLE>Don't let the gauge get all the way to the top - turn off the ignition before it gets there. Otherwise you could fry the gauge.
eth0r
Nov 10, 2005 03:31 AM
crucial-vtec
Oct 28, 2005 11:42 AM
Boofster
Dec 6, 2004 03:18 PM
pburke23
Jul 2, 2004 09:55 AM
erniecars
Jun 14, 2002 11:48 PM
