Technical build help b18c5 with B20 internals b16 head
Old Apr 9, 2013 | 07:24 AM
Rpicano's Avatar
Icon6 Technical build help b18c5 with B20 internals b16 head
Hey guys what's up finally joined Honda tech
Right now I have a high compression b20 vtec weisco piston ge rods type r
Internals in a b16 head 440 injectors crome tuning
Anyways I want a vtec turbo and ya I know the walls are thin on the b20
I can afford to sleeve but I heard some make it worse
The Car is a 95 Integra rs turned into a type r
So I want know if this is possible
I wanna pick up a b18c5 block use my polished b20 crankshaft
To make it a 2.0 and get some low compression pistons with my ge rods
Or just drop a b18c5 or keep the NA B20V
Thanks in advance guys
ITS VTEC BABY
Old Apr 9, 2013 | 06:29 PM
jdmsleeper12's Avatar
Default Re: Technical build help b18c5 with B20 internals b16 head
just drop the b18c5, call it a day! It can be daily/track/drag which ever u prefer. As long as you keep up with her maintenance she keep up with you!
Old Apr 9, 2013 | 06:33 PM
ekcoupeh22's Avatar
My race motor is a c5 block reworked ls crank turbo tuff rods ls length with cp pistons and a endyn b16 head
Old Apr 10, 2013 | 03:56 AM
Rpicano's Avatar
I love custom set ups like that and as for a straight b18c5 I like that too but
Does anybody know if the b20 crankshaft will fit in the b18c5 block with some
Low comPression pistons and should I bother sleeving the b18c5 block or do a block guard
To prep for boost
Thanks again for the help
MAD RESPECT
Old Apr 10, 2013 | 05:37 AM
ekcoupeh22's Avatar
To prep for boost
MAD RESPECT
Did you read what I wrote? I have a c5 block with an ls crank which is the same as a b20. Crank with 9:1 cp pistons. Don't do a block guard if your looking for less than 500 whp look at CSS very cost effective
Old Apr 10, 2013 | 06:59 AM
Rpicano's Avatar
My bad was half asleep lol sweet thanks alot man what about sleeving it I'm looking to make 350-400 hp what are you using for cams stock b16a
SpeedOFsmell
10
Dec 23, 2014 09:52 AM
that honda kid
23
Mar 22, 2010 07:17 AM
yoRt
Dec 3, 2008 05:08 PM
ef9itb
Jan 15, 2008 06:51 PM
90civichbsi
Mar 30, 2003 07:00 AM
