Tech guys, come solve the mystery problem: VIDEO
Old Apr 28, 2005 | 05:15 PM
milano2kdc2's Avatar
Default Tech guys, come solve the mystery problem: VIDEO
Heres my setup before I go on:
Port&polish head GSR head
Milled .30
Skunk2 valve springs
Skunk2 titanium retainers
Ferrea valves
Extrude Honed Skunk2 Intake Manifold
RPM throttle body
gsr injecters
fpr set at 48psi
B18c1 with PR3 pistons, new rings
New timing belt, water pump, tensioner
New OEM 3 layer headgasket with copper spray
I did everything to spec from the helms, every internal bolt is torqued to spec
Timing is correct
When I drive the car, I have to ride the clutch a lot just to move, and it wont go past 2400rpm. I use about 1%-5% throttle. When I shift to 2nd, pressing the gas doesnt do anything, the rpms just drop in gear as if I wasn't stepping on the gas
When I try to rev it a bit in neutral, the rpms drop and stall
And theres no colored smoke coming out the tail pipe, only condensation
No CELs
Help me on this thx
compression test
4, 3, 2, 1
210, 210, 200, 210
edit: video of the car starting and reving
http://home.comcast.net/~ken-chan62/h-t/vid.avi
Old Apr 28, 2005 | 06:29 PM
Outkast95LS's Avatar
Default Re: Tech guys, come solve the mystery problem: VIDEO (milano2kdc2)
bump so your motor can be done so you can race my friend
Old Apr 28, 2005 | 09:40 PM
sickerhatch's Avatar
Default Re: Tech guys, come solve the mystery problem: VIDEO (Nine5IntegraLS)
What type of engine management are you using?
Did you do any new wiring when installing the motor?
Old Apr 28, 2005 | 10:20 PM
honda at heart's Avatar
bump cuz the tow truck driver was lazy as hell
Old Apr 28, 2005 | 11:31 PM
Default Re: Tech guys, come solve the mystery problem: VIDEO (sickerhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickerhatch &raquo;</TD></TR><TR><TD CLASS="quote">What type of engine management are you using?
Did you do any new wiring when installing the motor?</TD></TR></TABLE>
stock obd2, and j's program p28 obd1. both had the same problem
Old Apr 29, 2005 | 10:20 AM
up
Old Apr 29, 2005 | 12:16 PM
Ron Carroll's Avatar
Double check your cam timing, it sounds like it is off.
Old Apr 29, 2005 | 12:31 PM
Default Re: Tech guys, come solve the mystery problem: VIDEO (itaintegra52)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itaintegra52 &raquo;</TD></TR><TR><TD CLASS="quote">Double check your cam timing, it sounds like it is off.</TD></TR></TABLE>
the timing is dead on, i lined it up with the oil pump markings, although the head is milled, it should still run correctly with the cams at 0,0
Old Apr 29, 2005 | 04:09 PM
JdmEKCivic's Avatar
did u try the stock ecu, also do u have any codes you might be in loop mode.
Old Apr 29, 2005 | 07:17 PM
MightyMouseTech's Avatar
Default Re: Tech guys, come solve the mystery problem: VIDEO (JdmEKCivic)
Are you sure you have gas in the tank (fresh gas?) it really sounds like you are running out of fuel (bad pump maybe?)
Old Apr 29, 2005 | 07:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEKCivic &raquo;</TD></TR><TR><TD CLASS="quote">did u try the stock ecu, also do u have any codes you might be in loop mode.</TD></TR></TABLE>
no CELs, tried stock ecu already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you have gas in the tank (fresh gas?) it really sounds like you are running out of fuel (bad pump maybe?)</TD></TR></TABLE>
yep, fresh gas from $2.94/gallon chevron
Old Apr 29, 2005 | 08:06 PM
marc.ejay-twenty's Avatar
i know exactly what's wrong...you're missing a turbo
Old Apr 29, 2005 | 10:03 PM
D-tuned's Avatar
Default Re: Tech guys, come solve the mystery problem: VIDEO (marc.ejay-twenty)
check your map sensor and tps
Old Apr 29, 2005 | 11:17 PM
Default Re: Tech guys, come solve the mystery problem: VIDEO (2000civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">check your map sensor and tps</TD></TR></TABLE>
already did
Old Apr 30, 2005 | 05:50 AM
JdmEKCivic's Avatar
chk your firing order, chk your base timing, fuel pressure, throttle cable
Old Apr 30, 2005 | 06:18 AM
D-tuned's Avatar
how old are the spark plugs? whats the gap on them
1999 Civic Si
48
Sep 10, 2016 10:55 AM
z_life
Jun 30, 2007 09:33 AM
turbociv
Aug 20, 2005 10:34 PM
milano2kdc2
37
May 2, 2005 01:29 AM
BlackSi325
Jul 10, 2003 01:53 PM
