Tech Guru's PLEASE HELP
OK, se here's the thing....I'm putting in new .5 mm oversize R pistons into my 94 gsr. My rods are reconditionable and I want to know if 01 R pistons OR CTR pistons will DIRECTLY fit onto the gsr rods without any modification?? Also, if I go with CTR pistons, would that cause problems with a daily driven car? Anyone with knowledge please help, I have been without my car for over a month and I need to know what way to go and I can't f*ck around and end up spending money on useless parts...thanks!
Quick note: factory oversize pistons are 0.25mm over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PainfulTeg »</TD></TR><TR><TD CLASS="quote">I'm putting in new .5 mm oversize R pistons into my 94 gsr.!
Where did you get a .5mm over bore ITR Piston?
As for Compression if you use a Standard to .25mm over then you will have a bit over 11.1:1 compression then if you use a Spoon or Mugen HG that should get the Comression right around where you want it.
I was mistaken, I talked to Len and factory honda goes no bigger than .25mm overbore.....I'm going with them instead and hopefully the .25 will be enough to remove all carbon scorring. If I have to go .5, I guess i'll be lookin into JE's or something.....
Slickrick936
Feb 24, 2011 12:39 PM
Shelton
11
Sep 20, 2004 08:12 PM
