Tech Guru's PLEASE HELP
Old Aug 13, 2003 | 02:21 PM
PainfulTeg's Avatar
Default Tech Guru's PLEASE HELP
OK, se here's the thing....I'm putting in new .5 mm oversize R pistons into my 94 gsr. My rods are reconditionable and I want to know if 01 R pistons OR CTR pistons will DIRECTLY fit onto the gsr rods without any modification?? Also, if I go with CTR pistons, would that cause problems with a daily driven car? Anyone with knowledge please help, I have been without my car for over a month and I need to know what way to go and I can't f*ck around and end up spending money on useless parts...thanks!
Old Aug 14, 2003 | 01:13 PM
Rocket's Avatar
Default Re: Tech Guru's PLEASE HELP (PainfulTeg)
Should have no probles with rod/piston compatibility.
CTR pistons will give you 12+ compression on a GSR motor. That's alot for 92-93 octane gas.
Old Aug 14, 2003 | 09:26 PM
PainfulTeg's Avatar
Default Re: Tech Guru's PLEASE HELP (Rocket)
yea, I didn't realize it would be so high, I thought maybe 11.6 or so.....I'm going with the ITR pistons, thanks for the help....!
Old Aug 14, 2003 | 10:40 PM
b19coupe's Avatar
Quick note: factory oversize pistons are 0.25mm over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PainfulTeg &raquo;</TD></TR><TR><TD CLASS="quote">I'm putting in new .5 mm oversize R pistons into my 94 gsr.!
Old Aug 14, 2003 | 11:48 PM
Spoond TEG's Avatar
Default Re: Tech Guru's PLEASE HELP (b19coupe)
Where did you get a .5mm over bore ITR Piston?
As for Compression if you use a Standard to .25mm over then you will have a bit over 11.1:1 compression then if you use a Spoon or Mugen HG that should get the Comression right around where you want it.
Old Aug 17, 2003 | 08:04 PM
PainfulTeg's Avatar
Default Re: Tech Guru's PLEASE HELP (Spoond TEG)
I was mistaken, I talked to Len and factory honda goes no bigger than .25mm overbore.....I'm going with them instead and hopefully the .25 will be enough to remove all carbon scorring. If I have to go .5, I guess i'll be lookin into JE's or something.....
Old Aug 23, 2003 | 10:43 AM
Spoond TEG's Avatar
I am sure you will be fine with the .25mm over
Look at the cylinder and feel inside.... If there is groove that is .5mm deep then yes you need to resleeve IMO
Slickrick936
Feb 24, 2011 12:39 PM
SL0-hatch
Sep 18, 2008 09:40 AM
mikkey1
Jun 13, 2006 11:52 AM
Shelton
11
Sep 20, 2004 08:12 PM
PainfulTeg
Aug 13, 2003 06:02 PM
