TDC Question
Old Jul 4, 2003 | 04:24 PM
Muckman's Avatar
Moderator in Chief
Default TDC Question
Gen2 Integra LS - Replacing Timming belt and tensioner.
Trying to put a new Tbelt on and following the helms directions. Helms says the middle notch on the crank pulley (marked red on the pic) is TDC on #1 cyclindar but I have a screw driver going thro the spark plug hole in the head resting on the piston (to indicate height of piston) and the "actual" TDC lines up with the white mark on the crank pulley. WTF is the deal with that? What is that white mark supposed to indicate? Should I install the Tbelt with the crank pulley on the red or white mark - Helms says red.
Modified by Muckman at 10:33 PM 7/4/2003
Old Jul 4, 2003 | 04:37 PM
Chiovnidca's Avatar
Default Re: TDC Question (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Gen2 Integra LS - Replacing Timming belt and tensioner.
The white mark is TDC. The red marks are for setting ignition timing.
Old Jul 4, 2003 | 06:34 PM
Muckman's Avatar
Moderator in Chief
Default Re: TDC Question (Chiovnidca)
ah ok. So how do I use the red marks to set my ignition timing?
Old Jul 4, 2003 | 06:38 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">ah ok. So how do I use the red marks to set my ignition timing?</TD></TR></TABLE>
The middle mark is spec, the outer marks are +-2 degrees
Old Jul 5, 2003 | 12:51 PM
Muckman's Avatar
Moderator in Chief
Whats the best way to get a timing belt on? Any tips?
Old Jul 5, 2003 | 01:45 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Whats the best way to get a timing belt on? Any tips?</TD></TR></TABLE>
I loosen the tensioner all the way, put the belt on the exhaust cam, take the slack out of the front of the belt, then slip the belt onto the intake cam.
Old Jul 5, 2003 | 07:50 PM
xteg95's Avatar
i dont know if youre supposed to do it this way but i put the belt on the intake cam and take the exhaust cam gear...put the belt on while its off and put it on. its kinda hard but you just gotta make sure you get the teeth right. we were just being lazy and didnt wanna deal w/the tensioner
RanCRX
May 6, 2012 10:55 AM
butter99
Dec 30, 2008 10:58 PM
omeara7
Jul 6, 2004 09:58 AM
StupidSlowRSX
May 5, 2004 03:58 PM
BIG RICH
Apr 3, 2004 09:10 PM
