TDC code 8 question
Old May 11, 2007 | 04:58 PM
hangac1093's Avatar
Default TDC code 8 question
I searched and couldn't come up with anything. I have a boosted 90 integra coverted to OBD1.Today I went down to NJ to Dyno tune my car. All the way down it ran perfect and did not over heat at all. We did to good pulls on the dyno, then it threw a code 8 (TDC). We went through everything and it is the distributer. So now the car is in limp mode, the car overheated a bunch on the way back to the shop and then I had it towed home. My question is Would this code 8 cause the car to overheat?
Old May 11, 2007 | 07:59 PM
AMS MIKE's Avatar
Default Re: TDC code 8 question (hangac1093)
headgasket perhaps?
Old May 11, 2007 | 08:02 PM
hangac1093's Avatar
Default Re: TDC code 8 question (AMS MIKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMS MIKE &raquo;</TD></TR><TR><TD CLASS="quote">headgasket perhaps?</TD></TR></TABLE>
I don't think so. I am not blowing any smoke and I have 180 and 179 across the board.
Old May 11, 2007 | 11:03 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hangac1093 &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think so. I am not blowing any smoke and I have 180 and 179 across the board.</TD></TR></TABLE>
when does the car overheat? all the time? right away? in traffic?
Old May 12, 2007 | 05:12 AM
hangac1093's Avatar
pulling up hills
Old May 12, 2007 | 08:55 AM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hangac1093 &raquo;</TD></TR><TR><TD CLASS="quote">pulling up hills</TD></TR></TABLE>
which equivilates to higher load.
Jump your fan switch so its on all the time and see if that helps.
if that doesn't help, its probably water pump or headgasket
Old May 12, 2007 | 07:41 PM
hangac1093's Avatar
if that doesn't help, its probably water pump or headgasket</TD></TR></TABLE>The guy who tuned my car said
"The retarded timing from the code causes the burn to be much slower...it puts most of the heat and combustion into the exhaust manifold which tends to heat that up so much that the because the radiator is so close, it cannot cool like it should be able to."
Old May 12, 2007 | 08:45 PM
AMS MIKE's Avatar
i got 50 cents to call "BULLSHIT" on what that guy told you!
One has nothing to do with the other. Your distributor is bad, not going to cause overheating when going up hills.
You have another problem and its most likely your water pump, thermostat, fan or headgasket.
what happened when you jumped the fan switch to put the fan on all the time. did it fix the problem or still does it???
Old May 13, 2007 | 04:23 AM
hangac1093's Avatar
what happened when you jumped the fan switch to put the fan on all the time. did it fix the problem or still does it???</TD></TR></TABLE>
I wont have the new dizzy untill monday. I have to put that in first to drive then I will have to go from there.
The fan worked when it was overheating so I don't think it is that. The thremostat is two years old, so that could be shot.
I dont know about the water pump.
And As for the head gasket. That was my first worry. So I did a compression test and came out with 180 in the #1 & 4 cylinders and 179 in the #2 & 3
If the head gasket was bad, the numbers wouldn't be that good right?
I will keep you updated.
Old May 13, 2007 | 03:05 PM
arc_55's Avatar
see the tdc sensor is only used for ignition timing at start up and supports the Cylinder position sensor if acting abnormal. I would change the TDC sensor in the dizzy and then address your cooling issues accordingly.
Old May 17, 2007 | 07:01 PM
hangac1093's Avatar
So i put in the new distributor and it is great no more over heating or code 8. On top of the bad distributor my DP bolts where falling out. Basically dumping HOT exhaust right on to my radiator.
Old May 27, 2007 | 08:27 PM
arc_55's Avatar
damn that sucks, but these are issues you have to overcome when it comes it performance. I would keep your old distributor and rebuild it, take it apart and you will realize how simple it really is. This way you will have a spare dizzy
Old Jun 2, 2007 | 08:11 PM
hangac1093's Avatar
Default Re: (arc_55)
Yeah. I had to send back the old dizzy. thats part of the lifetime warrenty deal.
VAAJ
36
May 7, 2009 07:35 PM
209typer
Oct 7, 2004 09:54 PM
swatdog
25
Mar 30, 2004 02:03 PM
AMG
Sep 2, 2003 07:03 AM
preluder
May 29, 2003 07:03 PM
