TB screw adjustments
Old May 22, 2006 | 04:41 PM
S-Type1's Avatar
Default TB screw adjustments
I have a D16Z6 with an idling problem: the engine drops off when the RPM dips too low.
so i had a question abou tthe throttle body screw. To raise the idle, do i turn it clock-wise or counter-clockwise?
I know its such a simple question, but an answer would help out alot!
Thanks
Old May 22, 2006 | 07:26 PM
JimBlake's Avatar
Default Re: TB screw adjustments (S-Type1)
It's a needle valve, usually counter-clockwise would increase idle speed.
Check the procedure for setting base idle (depends on model & year), you may want to warm it up, jumper the SCS connector, & unplug the IACV.
Crxdriver1989
Dec 19, 2017 01:28 AM
Jonathan_ED3
Jan 13, 2009 03:15 PM
walker111
Jul 14, 2008 06:31 AM
924doorEG
Nov 19, 2007 08:15 AM
