Taking off distibutor cap in d15?
Old Jan 10, 2003 | 09:27 AM
Kg cm2's Avatar
Default Taking off distibutor cap in d15?
There has been some crackling sounds from the distributor cap, so I took the plastic cap off, but I don't know how to get to the rotor inside, which I suspect is what is causing the noise. Can anybody tell me how to do this? Thanks.
Old Jan 10, 2003 | 08:01 PM
Kg cm2's Avatar
Default Re: Taking off distibutor cap in d15? (Kg cm2)
bump nobody knows?
Old Jan 10, 2003 | 08:20 PM
Kg cm2's Avatar
ttt
Old Jan 10, 2003 | 08:46 PM
Shawn C's Avatar
In The Garage
with distributer cap off, unplug distributer, then crank engine as quickly as you can, so it turns slowly, and wait until you see a set screw on the rotor. use a phillips screwdriver to take it out, and the rotor slides off. good luck
also, you might have to remove the internal coil (that black thing on top when you take the cap off. its got 4 screws in it, and the 2 wires screwed to it.
[Modified by 22lbGS-R, 5:49 AM 1/11/2003]
Old Jan 11, 2003 | 09:43 AM
Kg cm2's Avatar
Default Re: Taking off distibutor cap in d15? (22lbGS-R)
Thanks for the information, definitely a big help.
lmike6453
Feb 22, 2008 07:34 PM
paniaguae640
Nov 27, 2007 03:57 PM
bizmackus
Feb 25, 2007 09:33 PM
absolutgsr
May 28, 2002 11:53 PM
bocian
Feb 20, 2002 06:50 PM
