taking apart tranny questions....
Old Aug 15, 2003 | 10:13 PM
gumbybum's Avatar
Default taking apart tranny questions....
when i take apart my tranny do i take off the 12 mm bolts and then pull it apart? also what should i use to re-seal it? one more question how can i tell if the tranny is a b16 or a gsr? there are no codes stamped into it so could there possibly be some stamped on the inside of the housing? if anyone has torque specs can i have those too? thanks sooooo much guys you are saving me once again
Old Aug 16, 2003 | 06:33 AM
PupaScoopa's Avatar
Default Re: taking apart tranny questions.... (gumbybum)
A shop manual is a must for this job...
Pull the 12mm, pull the detent ball bolts, unlock the circlip, then pry apart. Reseal w/Hondabond or any ATV silicon sealant.
The b16 and GSR are identical I believe (anyone care to confirm?) I don't have torque specs right now. It's probably around 22lb/ft for the 12mm, you gotta tighten them in a criss-cross pattern. It's really fun getting the case back together...
Old Aug 17, 2003 | 03:14 PM
gumbybum's Avatar
Default Re: taking apart tranny questions.... (PupaScoopa)
thanks man. i have a chilton but it doesnt say anything about the tranny itself because the whole book is vague about everything. i heard that if you put the tranny into fourth then it is easier to get back together??? but there is no way to tell them apart because the gsr has a little bit longer gearing but ill have to just rip it apart and check it out.
thanks again man
also any other info will be very helpful thanks guys
seelyd
Jan 11, 2007 09:47 AM
hipity_hopity_mt
Nov 15, 2006 02:01 PM
H22A EG6
Aug 5, 2004 09:53 PM
gumbybum
Feb 6, 2003 07:57 AM
Nameless RB26
Nov 18, 2002 08:01 PM
