STR pro drag manifold. No Throttle cable bracket??
I'm in the process of installing the STR PRo drag manifold and I noticed there is no throttle cable bracket like the stock one on the LS. How do i connect it?
A friend of mine had the same problem and he just had someone custom make one or took the stock one and weld it on there. It worked out pretty good, and somehow they put it on the bottom so it's hidden, looks pretty cool..
It's underneath the manifold so you can't even see it. Just an option, if you don't like it don't do it. Only trying to give you an idea that my friend did and it doesn't look ghetto, honestly you cant even tell it's there.
you have to buy the throttle cable bracket separately. it took me about 3 months to figure out how that stupid thing worked.
JDM00SI
Jan 22, 2006 02:06 PM
NeXtLeVeL_TyPe_R
Nov 6, 2001 07:36 PM
