tachometer and motor skipping
Old Oct 16, 2003 | 01:38 PM
crxY-49's Avatar
Default tachometer and motor skipping
I did a search and didn't find much except the possibility of a bad ignitor. Has anyone experienced the tach jumping around and motor hesitating before? It seems to be getting worse. Any advice and pointers would be very appreciated...thanks.
Old Oct 16, 2003 | 02:24 PM
Dr. Si's Avatar
Default Re: tachometer and motor skipping (crxY-49)
I had a 92 Integra with the same problem. Check the coil for cracks. I replaced the igniter several times over the years and the problem was a cracked coil. The coil is located inside the distributor cap.
Old Oct 16, 2003 | 02:27 PM
crxY-49's Avatar
Default Re: tachometer and motor skipping (Dr. Si)
thanks...im pretty familiar with the parts inside the dizzy...i even have a spare coil lying around here somewhere. i'll try that out tonight
Old Oct 16, 2003 | 03:08 PM
dirty_d_cx's Avatar
i had a similar problem
weird enough i had something clogging up my fuel filter
it doesnt make any sence to me but it shure fixed the problem
Old Oct 16, 2003 | 05:47 PM
Xazzu's Avatar
Default Re: tachometer and motor skipping (dirty_d_cx)
yea, I was going to suggest fuel filter/injectors. periodic spurts of gas could cause that, eh?
Old Oct 16, 2003 | 07:37 PM
Mochanic's Avatar
Default Re: tachometer and motor skipping (Xazzu)
loose blue wire inside distributor on the right side of igniter... pull it off squeeze the female spade fitting a little tigher with some pliers and reinsert it.. your problem will most likely go away!
B16Turtle
May 28, 2009 01:03 PM
Chuji
Jan 8, 2005 11:53 AM
sincityEX
Nov 7, 2004 07:38 PM
H22edAccord
Jul 7, 2004 09:03 PM
customx_
Jun 18, 2002 11:30 PM
