tach problem
Old Nov 13, 2009 | 03:20 AM
wingsEK's Avatar
Default tach problem
i have a sunpro tach that i hooked up in my ek and it doesnt want to work until about 5k rpms ive checked it over and over to see if it might be a short and thats not the case. any suggestions?
Old Nov 13, 2009 | 04:39 AM
kyden's Avatar
Default Re: tach problem
do you have it set up for a 4 cyl?
Old Nov 13, 2009 | 05:58 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
What model of Sunpro?
Where did you connect the tach "pickup", [green I think] lead to?
How/where is the gauge grounded?
You also said "EK" is your Civic a JDM [RHD]? 94
Old Nov 18, 2009 | 10:27 AM
wingsEK's Avatar
the tach is an older model and it has 2 pick up wires, the accessory, ground, and power so a total of 5 wires from what ive been told im only supposed to use 1 of the pick up wires as the other is for a v8 so i had him help me with it and it still isnt working i have the ground(black) running to my chasis and the accessory(yellow) runnin to my interior lighting and the power(red) hooked up to the power wire off my gauges in my pillar. the pick up wire is hooked up to the green wire on my dizzy.
Old Nov 18, 2009 | 10:28 AM
wingsEK's Avatar
my bad its the blue wire on the harness right befor my dizzy not green
Acidcrakker
Nov 17, 2011 11:52 AM
slimjimdanny
Jan 31, 2007 07:35 PM
EJ8 GSR-T
11
Dec 7, 2004 12:08 PM
91hatchcivic
Aug 1, 2002 11:39 PM
