T-Belt off one tooth?????
Old Aug 19, 2002 | 05:29 PM
legendboy's Avatar
Default T-Belt off one tooth?????
Could I get 2 little drill bits steaked into the cams and cam caps to center them *UP* when putting my T-belt on but still be off by one tooth???? When my cam gears are centered up they are still a bit off, pointing inwards towards eachother but I could still get drill bits into the holes. My car runs a bit funny at idle.
Old Aug 19, 2002 | 05:49 PM
BreakStuff's Avatar
New User
Default Re: T-Belt off one tooth????? (legendboy)
Yes, you have to make sure the is no clearance within the holes.. the drill bit should be tight when you stick them in there and no play when you try to move the cam manually... it may appear to be snug, but you won't know until you try to spin the cam(s)
Spin the motor manually 2 revolutions counterclockwise after belt install and make sure your timing marks are still lined up..
Old Aug 23, 2002 | 07:12 AM
jetdriven's Avatar
Default Re: T-Belt off one tooth????? (BreakStuff)
i used two 3/16" roll pin punches avaliable at sears. There has to be no clearance or slop in the fitment of the pinpunches and the cam caps/cams. BTW my arrows didnt point exactly at each other when i did this.
Old Aug 29, 2002 | 06:20 AM
legendboy's Avatar
Default Re: T-Belt off one tooth????? (jetdriven)
Addicted 2 Adrenaline
Apr 14, 2009 09:07 PM
guedo148
Jul 30, 2007 08:05 PM
SrT4u2nV
May 23, 2006 03:55 AM
twistedbydezign
Aug 30, 2005 12:01 PM
junb16
Jan 27, 2003 09:44 PM
