T-Belt Curiosity
Old May 23, 2003 | 09:42 PM
blah13's Avatar
Default T-Belt Curiosity
Aight, my beater, 90 dx auto, has hesitation at low rpms so this weekend I'll be doing a general rundown, timing, cap/rotor, plugs etc. Personally I think my timing belt just jumped a tooth bc it happened suddenly and while I was revving a good bit. But after thinking about it I got to wondering some things...
The first thing is if when the belt jumps does it always jump in the same direction i.e. avdance or retard. And if so which, and if not then is it jus a 50/50 chance either way? I figure it would be the same way every time since the belt rotates in 1 direction.
So with that said and if 1 tooth on the belt is I think 16-18degrees would it be possible to "adjust" the timing back properly with an adjustable cam gear? I think 1 notch on the gear is 2 degrees, least thats what I remember hearing. So if 1 tooth is 16-18 degrees shouldnt this be possible?
I know its best to adjust the belt itself these were just thoughts that went through my head as I was thinking about it, and if anything is wrong or slightly off then correct me please. Anybodys thoughts are appreciated.
Old May 23, 2003 | 10:46 PM
MADEINIRAQ's Avatar
Default Re: T-Belt Curiosity (blah13)
I would check to see if it has jumped.. if so just put it back..
less work than installing a cam gear and adjusting it
you could probably adjust the cam gear to correct it but why?
Old May 24, 2003 | 06:47 AM
blah13's Avatar
Default Re: T-Belt Curiosity (madeiniraq)
It already has the adj cam gear on it. I tried removing the crank bolt from my ZC a while back and I couldnt do it without the engine trying to roll over (out of car) and since I have to have the dx running I'm not too keen on trying something that was damn hard on the ZC. Not to mention I dont have garage room with the EX in there and my driveway is gravel. So just looking for a temporary fix till I can get in my garage.
Stealthman80
Oct 25, 2005 09:12 PM
iwouldHITit
Apr 20, 2003 05:20 PM
