Synchro Replacement?
Old Aug 19, 2004 | 09:43 AM
ms1motorsports's Avatar
Default Synchro Replacement?
Just pulled apart a 99 Civic SI hydro tranny due to hard shifting and not allowing to get into gear once motor is runnig. Shifted into gear when the motor was not running though. I checked the synchros and all of them look good. No missing teeth or worn teeth. What else should I check for to see if the synchros are bad? I'll also be replacing the clutch. Any input on figuring out why the tranny shifted hard and sometimes got locked out of all gears would be greatly appreciated. Thanks.
Old Aug 19, 2004 | 12:27 PM
Default Re: Synchro Replacement? (ms1motorsports)
Any ideas?
Old Aug 19, 2004 | 02:32 PM
hondatim's Avatar
It doesn't sound like you have bad trans...
Sounds like you have bad clutch (e.g. broken pressure plate spring, clutch disc spring hanging up) or something else in clutch disc assembly causing clutch to not fully disengage.
Old Aug 19, 2004 | 02:47 PM
Default Re: Synchro Replacement? (hondatim)
That's what I was thinking. None of the synchros looked bad. I'm changing the clutch and I'll see if that fixes all my problems.
Old Aug 19, 2004 | 04:23 PM
murtnabila's Avatar
sounds like clutch problem...I had same problem, but not all the time just sometimes. When replaced clutch problem went bye bye
Old Aug 20, 2004 | 07:26 AM
I took the clutch off and replaced with a stage 2. The old clutch plate was starting to bend and split the metal around the springs. Also the pressure plate had metal pieces loose inside of it. They looked like the fingers that were inside of the pressure plate. Should of solved my problem. Thanks.
Old Aug 20, 2004 | 09:31 AM
murtnabila's Avatar
Dc295kid
Dec 19, 2009 07:05 AM
snakepirates
11
Jun 9, 2006 01:40 PM
dan89crxsi
35
Oct 25, 2004 03:17 PM
Hondaman56
Oct 23, 2004 10:10 AM
b18cya
Mar 31, 2003 10:40 AM
