Switching to the dark side?
Old Aug 26, 2009 | 11:34 AM
bibby's Avatar
Default Switching to the dark side?
I'm thinking of trading my 92 EG with a d16y8 swap for a crx si with a b16a ls trans swap. Only for the motor/trans and any other good parts because the crx doesnt have a title.
The fuel pump is out on the car which is why it don't run. I disconnected the gas line at the fuel rail and nothing came through. Also the fuel pump did not engage, but i;m not really concerned about the car. I jsut wanted to hear the motor turn over, which it does. Great. Absolutely wonderful. On the 4th when i get paid I'm putting tags on my extra vehicle so me and the wife both have something to drive. The rex will then be in the garage and I'll begin pulling the b16. I'm going to save the body until i find a good crx shell then use it for parts until the swap is done, then part out the rest, and scrap it. There are several good shells online. B) One on d-so I'm particularly interested in. What do you guys think? Good deal? I have $1300 invested in my car (body, motor, auto swap and misc things).
I posted this here,, because i'm an active member on d-so, but i'm not getting much input there on the B swap.
Vid...
[youtube]xXI_YT0Co6Q[/youtube]
Pics...
Old Aug 26, 2009 | 11:45 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Switching to the dark side?
sounds like a hassle to realy nothing no offense. keep the eg
Old Aug 26, 2009 | 11:49 AM
bibby's Avatar
I like projects. Thats how i got my EG. I bought the shell, then a motor, then manual swapped it. I know what complete b16 swaps are worth, and its worth more than i have in this car ($1300). I'm already bored with my car cause its finished, and its not really what i wanted. I wanted a CRX, or EG hatch, but i settled for this 4 door.
Old Aug 26, 2009 | 11:56 AM
I'm not Rick!
well if thats what you want. then do it. good luck
Old Aug 26, 2009 | 02:21 PM
bibby's Avatar
Can anyone tell me what car this is out of? Guy is telling me its from a 92 integra LS. All the info i can find on LS's are b18's. This is a GSR motor right? I want to find the HP/vtec/redline numbers on it. All i know is B16A. I dont know B16Awhat.
Old Aug 26, 2009 | 02:28 PM
eyehategod666's Avatar
not a gsr motor you even posted a pic that says b16a come on people use your brain
Old Aug 26, 2009 | 02:35 PM
bibby's Avatar
I dont know much about B's. What car did this come out of so i can research the numbers on it?
Old Aug 26, 2009 | 02:52 PM
TunerN00b's Avatar
In the US, the B16 is only from the 99-00 Civic Si.
In Japan, many different years of Civic Si had a B16.
Old Aug 26, 2009 | 02:55 PM
bibby's Avatar
How do i know itf its a JDM b16, or USDM b16?
If its usdm, its most likely B16A2 right?
B16A2
* VTEC
Found in:
o 1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
o 1992-1997 Honda Civic Del Sol EDM VTi (EG)
o 1996-1997 Honda Civic Del Sol USDM "VTEC"
o 1999-2000 Honda Civic USDM Si (EM1)
o 1999-2000 Honda Civic CAN SiR (EM1)
o Displacement: 1,595 cc (97.3 cu in)
+ Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
+ Compression: 10.2:1
+ Power: 160 bhp @ 7600 rpm & 118 ft·lbf (151 N·m) @ 7000 rpm
+ Transmission: Y21 or S4C
+ Redline...8,000 RPM
+ Rev Limit...8,450 RPM
+ VTEC Engagement...5,500 RPM
Old Aug 26, 2009 | 03:14 PM
your motor is a jdm b16
Old Aug 26, 2009 | 03:20 PM
bibby's Avatar
So i'm looking at this for specs?
B16A
Note: All JDM B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
* VTEC
* Found in:
* JDM Honda Integra RSi/XSi (DA6/DA8)
o 1988-1991 JDM Honda CRX SiR (EF8)
o 1988-1991 JDM Honda Civic SiR (EF9)
+ Displacement: 1,595 cc (97.3 cu in) 1.6 liter
+ Bore: 81.0 mm (3.2 in)
+ Rod/stroke ratio: 1.745
+ Power: 118 kW (160 PS; 158 bhp) @ 0 rpm & 111 ft·lbf (150 N·m) @ 7000 rpm
+ Transmission: S1/J1/Y1
+ Transmission: S4C/Y21 (Some with LSD)
+ Redline: 8200 rpm
Before i pull the engine how can i tell if its LSD?
Old Aug 27, 2009 | 07:03 AM
robfrmny21's Avatar
take a axle out. if you can clearly see the other axle inside the tranny from you end you got lsd. if there is something blocking your lien of sight of the axle it is non lsd will look like a big metal pin
Old Aug 27, 2009 | 07:45 AM
vtecnician-eg6's Avatar
New User
also the tranny will be stamped with lsd on it. lsd is typical on most jdm trannies attached to b16a's
Samson123
Classic Hondas
Aug 16, 2018 02:24 AM
Wildman91
Feb 26, 2015 05:11 PM
Leperchon
Dec 1, 2003 12:10 PM
gixxer6
Nov 7, 2002 04:31 PM
