swapping in a d15b into a automatic 95 civic ex
Old Sep 24, 2004 | 09:33 AM
mrpeabody's Avatar
Default swapping in a d15b into a automatic 95 civic ex
Ok, i'm just swapping out my brothers d16z ex sohc vtec motor for a d15b 1.5 vtec motor. the car ia a automatic, so basiclly i'm just changing motors. the question i have since i have never swap a automatic out, i was wonder f anythign special was needed for the swap. i have done a manual tranny, but not a automatic. is the proccess that same. also the car is a ex/the new motor is a d15b(jdm) with the 130hp. also last question, do i need the ecu from the 1.5 d15b?
Old Sep 24, 2004 | 10:56 AM
mrpeabody's Avatar
Default Re: swapping in a d15b into a automatic 95 civic ex (mrpeabody)
bmp
Old Sep 24, 2004 | 03:11 PM
Katman's Avatar
I haven't performed this type of swap either, but I do know you WILL need the ecu for the auto engine. So, keep the auto EX ecu and use it on the D15B engine.
Old Sep 24, 2004 | 03:26 PM
mrpeabody's Avatar
Default Re: swapping in a d15b into a automatic 95 civic ex (Katman)
thanks for the info. i asume it will be just like a manual swap, just with a auto trans. the clutch per say install should be the same right?
Old Sep 24, 2004 | 03:41 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrpeabody &raquo;</TD></TR><TR><TD CLASS="quote">..the clutch per say install should be the same right?</TD></TR></TABLE>
I assume it would be the same. Like I said, I haven't done this specific type of swap either.
Old Sep 24, 2004 | 10:12 PM
mrpeabody's Avatar
Thanks KATMAN your the best.
Old Sep 29, 2004 | 12:06 PM
Katman's Avatar
crxnonvtec
Dec 22, 2005 10:44 AM
jspecPR26
Aug 8, 2005 03:54 PM
darb2k
12
May 1, 2005 06:45 PM
5thGenCivicKid
10
Mar 10, 2004 03:46 PM
