Swap wiring help please!!!
Ok, i have a 1996 del sol
and I just got my b16a2 to throw in ther
yes, i knwo the car is obd2, and so is the new motor
my question is...can I plug the ecu from the b16a directly into my wiring harness for the d16y8 sohc vtec motor???
or is a tonne of splicing required???
you will have to pin in or cut and solder in the vtec selonoid, knock sensor vtec oil pressure and then your good unl;ess you have a d16y8 in it then all you have to do is add a wire for the knock sensor to the ecu
msinsky14
Mar 27, 2006 05:53 PM
ekb18cCivic
Feb 24, 2004 06:27 PM
4g4me
Apr 22, 2002 09:23 AM
