swap help
Old Feb 1, 2006 | 03:17 PM
pkgwjai082's Avatar
Default swap help
im swapping an 96 ls motor into my 97 civic hatch. I was just wondering if i shoul just use my stock ecu and wiring harness, or should i swap it to the ls ecu and wire harness. Im pretty sure i can use the stock one from my car but i just want to be sure. Thanks
Old Feb 1, 2006 | 04:59 PM
Blaze45's Avatar
Brrraaaap!
Default Re: swap help (pkgwjai082)
If you match what OBD year your car is then it should just swap over. The motor doesnt really matter, what matters is what injectors ECU and distributer your running. Stay obd1 with everything and you'll be fine. Some wires my need to be extended for sensors n such but other then that you should be fine.
Your going to need
0bd1 LS dizzy
0bd1 ECU
Jeez I think thats it.
Blaze
Old Feb 1, 2006 | 05:05 PM
freadyg's Avatar
Default Re: swap help (Blaze45)
i know this is only a trial membership but i only want to know what would be the best motor to put into a 92-95 civic hatch.
Old Feb 1, 2006 | 07:48 PM
pkgwjai082's Avatar
actually i think i might be fine with the swap over because i the motor and my car both are obd2
Runamok81
Honda Civic (2001 - 2005)
10
May 13, 2020 03:21 PM
EG-Coupe
18
Oct 6, 2009 02:50 PM
pmpm06
Dec 13, 2007 03:37 PM
slammed00si
Feb 23, 2007 10:04 AM
cxhb
Sep 6, 2005 10:15 PM
