surging problem at 2000RPM
Old Dec 31, 2004 | 09:39 AM
suspendedHatch's Avatar
Default surging problem at 2000RPM
When I'm cruising or accelerating lightly, once the RPMs hit about 2000, the engine starts surging up and down from 1900 to 2100 RPM. If I give it more throttle or downshift it runs smooth as long as I'm not within that RPM range. I've done all the normal tune up stuff. In fact, I've had this same problem before and after an engine swap. Any suggestions?
93 Civic w/SOHC Vtec
Old Dec 31, 2004 | 06:03 PM
eg6T's Avatar
Default Re: surging problem at 2000RPM (shaundrake)
fitv
Old Dec 31, 2004 | 06:28 PM
hondaguyef's Avatar
Default Re: surging problem at 2000RPM (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">fitv</TD></TR></TABLE>
that or, a vacum leak.
Phil
Old Jan 1, 2005 | 08:36 AM
Default Re: surging problem at 2000RPM (hondaguyef)
Oh. I bypassed the FITV. Does this mean that I have to put it back?
Old Jan 1, 2005 | 12:28 PM
DaZman69's Avatar
doesnt sound like a FITV to me......spray some carb cleaner on all of the vacuum lines/Intake manifold. See if it stops revving. The carb cleaner if sucked in will richen the mixture temporarily and stop it from revving.
Old Jan 1, 2005 | 02:17 PM
eg6T's Avatar
Default Re: surging problem at 2000RPM (DaZman69)
it was revving like that for me..it was my fitv
Old Jan 2, 2005 | 09:43 AM
It's not doing it at idle. It idles perfectly. Besides, when the coolant warms up, the FITV closes, but my problem happens hot or cold.
Old Jan 2, 2005 | 02:51 PM
DaZman69's Avatar
that why its not your fitv, cause that only effect idle.
BTW, your fitv a loose fitv will not always stop when the car warms up. If its unscrewed enough it will do it all the time. Mine did it for about a month until it was all the time.
Old Jan 2, 2005 | 02:54 PM
eg6T's Avatar
i didnt say it was doing that for me at idle,it did it at idle and when it was warmed up,i fixed the fitv,and it stopped.im not saying that it IS your fitv,im just saying thats what it was with me,at idle and warmed up
PROJECT 91
Sep 25, 2009 11:18 AM
blackE_T
Feb 4, 2005 01:59 PM
TypeRPaul
May 21, 2004 05:43 PM
slammin86
13
Jan 9, 2004 05:36 PM
0 0 0
30
Dec 18, 2002 06:25 PM
