supercharger vs turbo
Old Jan 3, 2002 | 10:24 AM
Grimm's Avatar
Default supercharger vs turbo
A novice question but... what is the difference between a supercharger and a turbo. As in power gain both torque and HP. Plus's and minus's on each. Best bet for a 96ex d18y8 engine.
Old Jan 3, 2002 | 10:29 AM
WAFFLES's Avatar
Default Re: supercharger vs turbo (Grimm)
First off----not being rude but you have a d16----okay now
Superchargers like Jackson's would be good for you since you don't want to work on your car a lot. Most low boosting forms of FI will be reliable, but Jackson's are proven. Turbos---go with a kit from someone like greddy or HKS or Apexi. Keep the boost levels low, between 6-8psi.
Spade's Avatar
Superchargers are belt driven.
Turbos are powered by the exhaust. http://www.howstuffworks.com has an example of how a turbo works. Probably one on a supercharger as well.
There is a "loss of power from using the belt to drive power but, it is always moving "enough" air.
While with a turbo you have to wait for it to spool up there fore power really doesn't exsist until higher RPM's which depend on the trim of your exhaust blades on the turbo.....yadda yadda there are many many determining factors for both sides however, a Supercharger would be best for street driving since it provides pwoer throughout the power band.
[Modified by Spade, 11:32 AM 1/3/2002]
Old Jan 3, 2002 | 11:37 AM
Grimm's Avatar
Default Re: supercharger vs turbo (Spade)
hey spade thanks, I checked it out and got me some knowledge on the topic, It didn't really go into to much detail on a supercharger though, so my remaining question would be: A turbo is adjustable as in Psi's and boost due to the psi's is that theory applied in a supercharger, if so, how.
Old Jan 3, 2002 | 11:39 AM
Spade's Avatar
Yup, with the supercharger you change the pulley sizes.
Edit: Oh, here is a somewhat decent explanation of the superchager. http://www.jacksonracing.com/pages/howorksh.html
[Modified by Spade, 12:45 PM 1/3/2002]
Old Jan 3, 2002 | 11:49 AM
Grimm's Avatar
so it's not something you can do while driving infact it's kinda you get what you get. where as a turbo you can alter the mix at any given moment? granted you have a controller that will allow you to. then another question (again) not covered in that article or the others I glanced at. A turbo timer? does it just hold the turbo from creating boost until a certain point or what?
Old Jan 3, 2002 | 11:53 AM
WAFFLES's Avatar
turbo timers keep the turbo running after the car is shut off. It allows it to cool properly as to not damage the bearings.
Old Jan 3, 2002 | 11:54 AM
Spade's Avatar
With the turbo you don't actually modify that you modify the Wastegate....which opens at a specific PSI to maintain that PSI.....you control that wastegate and make it open at a higher PSI.
Old Jan 3, 2002 | 11:57 AM
Grimm's Avatar
thanks guys you definatly made it all make sense. Sorry i posted this in tech and not forced induction.
Old Jan 3, 2002 | 11:58 AM
Spade's Avatar
Doesn't matter, it is technical isn't it. Besides it gets boring here.
BTW: more on superchargers http://www.sportcompactcarweb.com/ar...ech02_0701.jsp
And more http://www.sportcompactcarweb.com/ar...ech01_0201.jsp
[Modified by Spade, 12:58 PM 1/3/2002]
Old Jan 3, 2002 | 12:27 PM
Grimm's Avatar
so it looks to me that the Centrifugal Superchargers are the way to go. They give the best constant boost throughout the entire powerband. so i ask why turbo a car when you can supercharge it and have instant boost? is it that a turbo is just easier to customize (tune) to daily driving conditions opposed to having only one size pulley (gear)?
Old Jan 3, 2002 | 12:34 PM
WAFFLES's Avatar
turbos tend to make more power total.
You know how ac takes power away from you car from the pulleys, same thing with sc.
Old Jan 3, 2002 | 12:41 PM
Grimm's Avatar
Default Re: supercharger vs turbo (WAFFLES)
gotcha could that be corrected with an under drive pulley, so essentially the supercharger dosen't suck anything away or are under drive pullies not that great?
Old Jan 3, 2002 | 12:43 PM
WAFFLES's Avatar
they will help
ChrisRondon
Apr 23, 2012 11:06 AM
Roboy88
Honda Civic (2006 - 2015)
Sep 21, 2008 10:15 PM
shawn5989
17
May 24, 2008 05:57 PM
Demonis
10
Aug 12, 2006 05:58 PM
krings
May 9, 2003 01:26 AM
