Stud replacement - Hub removal - Integra Type R
Old Sep 19, 2004 | 06:46 PM
slowassR's Avatar
Default Stud replacement - Hub removal - Integra Type R
About a year ago I had to change my stud and it sounded like the hub had to be removed to replace the studs. I did some searching though Honda-tech and talked to some people.
Recently, I had to change my studs and my Honda-Tech searching still came up with the same info... take off the hub, maybe or maybe not replace the barring.
This time we changed 10 studs with out remove the control arm or removing the hub.
We took off the wheel, caliper, and dust cover. We hit the studs with a hammer so they had about a 20 degree bend in them.
Right under the tie rod end, on the hub, there is a spot that is close to a cut out. Just line the stud up and knock it out. As long is the old studs have a little bend (or are already broken) they will pop right out.
The new studs will pop right in though in the same spot with no prob.
Thought I would post this info out there to save some Ht's some time and money.
Slowass
-Luke
Modified by slowassR at 7:46 PM 9/20/2004
Old Sep 20, 2004 | 02:23 AM
Slow_Em1's Avatar
Default Re: Stud replacement - Hub removal - Integra Type R (slowassR)
why uh thank ya!
:hickvoice:
Old Oct 3, 2004 | 10:05 AM
blaster834's Avatar
thanks can this be done with extened studs as well?
Old Oct 12, 2004 | 04:26 PM
slowassR's Avatar
Default Re: (blaster834)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaster834 &raquo;</TD></TR><TR><TD CLASS="quote">thanks can this be done with extened studs as well?</TD></TR></TABLE>
I think it can.
I had to replace some more studs and it took about 30 min.
I took some pics on the digi cam. Ill have to post them up
Old Oct 13, 2004 | 10:23 AM
slowassR's Avatar
Default Re: (slowassR)
Heres the pick
Old Apr 22, 2006 | 02:47 AM
Sifu's Avatar
SOrry to bring up an old thread but Im gonna have to replace my stud this weekend and was wondering can someone re-post the pictures?
Also if possible some more information on this?
Thanks
Old Apr 27, 2006 | 05:11 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassR &raquo;</TD></TR><TR><TD CLASS="quote">We hit the studs with a hammer so they had about a 20 degree bend in them.</TD></TR></TABLE>
My concern here is that if you hit the stud hard enough to bend it, you could be bending the hub and/or damaging the bearing as well.
Old Apr 27, 2006 | 05:19 AM
Sifu's Avatar
^^ Still bloody impossible to put in a new one!
ewoo
Feb 24, 2009 04:23 PM
SomeGoodBud2
Suspension & Brakes
Mar 18, 2007 02:48 PM
philkehn
Nov 1, 2006 09:54 AM
coupedup
Jun 26, 2003 06:12 AM
ekb18b5
Dec 24, 2001 04:47 AM
