Stroked B18C1
Old Dec 3, 2003 | 03:59 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Stroked B18C1
anyone running a stroked B18C1? what are the pros and cons? street friendly?
Old Dec 3, 2003 | 04:07 PM
Kendall's Avatar
Default Re: Stroked B18C1 (SnoFlake EG)
The stroke of the engine really wouldn't have a lot to do with streetability of the car. What you would get is more torque at low rpm's as well as an increase in peak power, and very likely a decrease in the point of peak power output as well as a decrease in redline assuming all other variable were the same (compression, cams, timing, etc.). This would actually make it more street friendly to some people due to the increased low end torque. The motor would also be less rev happy. However in a race engine, the increased torque and displacement can make for some crazy fast setups when the engine is properly built.
Old Dec 3, 2003 | 04:12 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Stroked B18C1 (dc231)
thanx for the info bud...not to be rude but i know what stroking a motor is/does ..im just asking anyone who has it on their street cars what they think/thought of it!
Old Apr 10, 2004 | 10:55 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
ttt
Old Apr 10, 2004 | 11:06 AM
mchuang's Avatar
Got a stroked b16 to 1.8 and rev it to 10000 rpm all day long. What size stroke you runnin in your b18c. Try to keep your rod stroke ratio above 1.5
Old Apr 10, 2004 | 02:23 PM
N2O's Avatar
N2O
Default Re: (mchuang)
We ran a stocker motor last year and it was overkill. You can make all the power you need out of a stock b18 crank. I would spend my money on something else. It will be ok on the street. However like I said you can make all the power you need on a stock Honda crank.
Good luck
raverx3m
24
Dec 10, 2012 10:18 PM
quicksilver1689
Aug 24, 2007 02:39 PM
chanksta06
May 11, 2006 04:43 PM
Screamer
119
May 6, 2004 07:20 AM
archmage
Nov 30, 2001 11:57 PM
