Stripped Bolt Head
Old Feb 22, 2005 | 02:40 PM
pumonchu2005's Avatar
Default Stripped Bolt Head
I have a stripped bolt head on my distributor mount. It is not possible to jam a smaller socket on it because I can't get the wrench on it, I can't drill an extractor bit on it because it's at a weird angle, it is so rounded I can't fit any open-end wrenches, and I've tried vice-grips but those don't work either...
Any suggestions? I really need to get this bolt off, the ******* who put the new cap on advanced my timing and now it's pinging like a toddler who got into the pots and pans cupboard.
Thanks
Old Feb 22, 2005 | 02:57 PM
PrettyLude's Avatar
snapon.com, look for some twist sockets
Old Feb 22, 2005 | 03:21 PM
beaterdriver's Avatar
http://www.sears.com/sr/javasr...65000
they sell cheaper ones i think
Old Feb 22, 2005 | 03:22 PM
Default Re: (PrettyLude)
thanks for the suggestion! I'll have to find a store that carries em.
Old Feb 22, 2005 | 03:24 PM
Default Re: (beaterdriver)
those are way too deep. The i can barely fit a 1/4" width wrench in there. I think I may have to saw it then drill it or something. It does have a phillips head, but it's at such a bad angle i can't get a screwdriver in there tightly.
Old Feb 22, 2005 | 06:54 PM
Mr. Samurai's Avatar
Default Re: (pumonchu2005)
not sure if this will help you but when i had a rounded nut i took it to a friend of mine who welded another nut on there and we took it out from there. might wanna try that before you go and chop off the head.
Old Feb 24, 2005 | 08:02 AM
Default Re: (L33T)
I've thought about that, but it might still be too tight of a space, unless of course I fit a smaller diameter bolt on there. Thanks for the suggestion.
Old Feb 24, 2005 | 08:55 AM
Honda Hick's Avatar
Default Re: Stripped Bolt Head (pumonchu2005)
If you can fit a cutting tool in there you can just grind/saw the head off. Once the distributor is off then you can probably just unthread the existing bolt out by hand because the pressure of the head won't be on it.
RomesEM1
Dec 12, 2009 04:05 PM
bow tie
Nov 15, 2008 05:11 PM
Hondaholik
Jul 24, 2006 02:31 PM
chriskona
Welding / Fabrication
Feb 15, 2005 06:47 AM
ltho1998
Aug 16, 2003 06:59 PM
