Strange problem on B18C Type R
Old Jun 12, 2009 | 05:09 PM
Kerplunk's Avatar
New User
Default Strange problem on B18C Type R
Hi, I'm visiting this forum for a long time now and I finally decided to subscribe. I am experiencing problems with my engine that I couldn't find
any information to fix it.
By the way I'm from Montreal, I'm trying my best to write in english but there will may be some errors...
So here's my problem...
When the car is warm and I am rolling for about 20min, when I start from a stop, the engine is ''bucking'' a little bit between 1500 and 3000rpm.
It's worst when it is very hot outside. At WOT theres is no problems.
My setup is:
Civic 96 with stock B18C Type R '97 p73 ECU
SRI AEM
Exhaust 2'' 1/4 with 22'' resonator, high flow cat and Dynomax muffler
HKS sparkplugs
I recently replaced cap/rotor and the fuel filter.
I am thinking that maybe the O2 sensor is broken, but I have no CEL.
Or I am wondering if the short ram could be the cause ? It becomes very
warm under the hood and maybe the air coming in the engine is too hot ?
My center console where the handbrake is also becomes very warm after rolling for a few minutes.
Thank you for reading my post !
Old Jun 14, 2009 | 01:39 PM
Kerplunk's Avatar
New User
Default Re: Strange problem on B18C Type R
anyone has an idea ??
Old Jun 14, 2009 | 01:59 PM
Ruben19's Avatar
is the engine overheating?
have you replaced spark plugs & wires.
problems started after or before you replaced cap/rotor?
Old Jun 14, 2009 | 02:01 PM
Dogginator's Avatar
Daisy... Daisy...
That ECU should tell you about misfires, etc. Do you have a check engine light? Check the CEL codes.
Old Jun 14, 2009 | 02:46 PM
Kerplunk's Avatar
New User
The problem began before I changed the cap/rotor. I didn't replaced wires and sparkplugs because they seemed to be OK. The engine is not overheating the temp gauge is at its normal position, and I dont have a CEL ...
Old Jun 15, 2009 | 09:31 AM
civic251's Avatar
Check the voltage of the TPS at the ECU, should be 0.45-0.50v closed and 4.5v at WOT.
uzi boy
Oct 22, 2012 05:00 PM
tippatone
Aug 8, 2012 08:47 PM
landon2992
15
Nov 6, 2010 11:16 AM
krazeenoy
Mar 19, 2008 09:50 PM
