Strange charging problem...
Old Mar 26, 2003 | 09:42 PM
Smashback's Avatar
Default Strange charging problem...
Well, I just got my car running after doing a b18 swap. I had to use an SPAL fan to clear the turbo. Other than that, there's nothing electrical that's new (that I can think of).
I ended up getting a freshly rebuilt alternator. So today, I drive it and voltage reads 14.xx so all is well. Then for no apparent reason, the voltage drops to 12.xx and the car stutters and runs like ****.
Any ideas?
Old Mar 27, 2003 | 05:46 AM
JimBlake's Avatar
Default Re: Strange charging problem... (Hatchblack)
Dumb first guess is loose or corroded connections to the alternator, including grounds. Engine ground too.
Old Mar 27, 2003 | 05:52 AM
JasonG's Avatar
Keep it simple. Check wires and connections and maybe even belt tension.
Old Mar 27, 2003 | 08:21 AM
Smashback's Avatar
Default Re: Strange charging problem... (JasonG)
Yeah, these were all my first thoughts. Belt tension seems fine. Also checked battery connections, alternator connections and engine ground. I've got a 10ga ground from the chassis to the valve cover, and an 8ga ground from the chassis to the tranny.
Still not sure, might be a ground problem I suppose. If I turn on the stereo I get a massive whirring sound, so bad I really can't listen to the stereo. When the voltage drops, of course, I get a bad crackling - seems like it can't supply enough power to the amps (Punch 500, Punch 300, and 1 farad cap).
Ugh!
On the upside, it's fast as hell. Seems faster at 5 PSI than the SOHC did at 9
Old Mar 27, 2003 | 03:32 PM
PnX-R's Avatar
That does seem strange.. Did you ever happen to think that it might be because it's a REBUILT Alternator.. Maybe it wasn't put back together right.. But hey, who am I to say anything..
Old Mar 27, 2003 | 09:00 PM
fsarfino's Avatar
Default Re: Strange charging problem... (PnX-R)
I kinda had a similar problem in my CRX with a b16 swap.
When my orginal alternator went bad I replaced it with a 2 rebuilt aternators and both of them would work for about 15 minutes then the dash light would come on so finally I replaced it with a rebuilt one from Honda and never had any more problems with it.
BTW If you do replace it with one from Honda be prepared to pay about $100 more than what the autoparts stores charge.
Old Mar 27, 2003 | 11:31 PM
Smashback's Avatar
Default Re: Strange charging problem... (fsarfino)
Ah this crap is just weird. I gotta check everything over when I get some time.
Ooh rah!
Justin Alvizo
Jan 7, 2016 06:50 PM
patrickstar
Apr 15, 2009 04:10 PM
Duck*
Feb 16, 2004 09:40 AM
_jester_
Dec 13, 2003 11:20 AM
