stock tach going crazy
Old Aug 21, 2004 | 02:42 PM
lsvtec101's Avatar
Default stock tach going crazy
lsvtec obd2b-obd1 converter harness w/ kenji chip , just before 5200 the tach goes crazy, back and forth.. any suggestions?
Old Aug 21, 2004 | 03:58 PM
Dragline's Avatar
Default Re: stock tach going crazy (lsvtec101)
What kind of tach
Old Aug 21, 2004 | 04:46 PM
lsvtec101's Avatar
Default Re: stock tach going crazy (dragline)
stock tach
Old Aug 21, 2004 | 05:07 PM
Dragline's Avatar
Sounds like a loose connection or ground.
Old Aug 21, 2004 | 06:44 PM
jmk2888's Avatar
It could be the ignitor, I had the same problem.
But mines did that when I went over 4000 RPM.
Old Aug 24, 2004 | 12:02 PM
lsvtec101's Avatar
Default Re: stock tach going crazy (jmk2888)
any other suggestions? Dizzy is brand new.
Old Aug 24, 2004 | 12:14 PM
Adam.'s Avatar
I have the same exact problem, however, mine is with an OBD1 H22. I ended up just hardwiring the blue tach signal directly to the stock tach. Wish i could've figured this out.
Old Aug 24, 2004 | 12:56 PM
lsvtec101's Avatar
Default Re: stock tach going crazy (DarkKnight[DMD])
this fixed the problem? could it be a loose connection on the obd2-obd1 harness? which wires are for the tach?
Old Aug 24, 2004 | 01:05 PM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec101 &raquo;</TD></TR><TR><TD CLASS="quote">this fixed the problem? could it be a loose connection on the obd2-obd1 harness? which wires are for the tach? </TD></TR></TABLE>
It fixed my problem and I rev up to aroudn 7700 now. Off the dizzy it is a blue wire. I don't know which wire you are looking for in your harness. You'll need to get a diagram to figure out which in your cluster is for tach signal.
I believe it is blue as well, but don't quote me.
Old Aug 24, 2004 | 01:31 PM
lsvtec101's Avatar
thanks man
CLE
12
Oct 31, 2007 07:31 PM
Beezle
Nov 2, 2004 10:33 AM
WhiteEG6
May 20, 2004 03:57 AM
Eg6_JDM
Mar 18, 2002 10:33 AM
