still leaking???
Old Nov 20, 2004 | 09:44 AM
DrewQ1's Avatar
Default still leaking???
I replaced my valve cover gasket and spark plug tube seals and I still ended up having oil in my sparkplugs and i see light residue of oil around the valve cover. why is that, i belive i tightend the studs as tight as possible but i was also told you dont want to tighten it to much or you can snap the studs, do i need to just tighten them just a little nudge more or what help me out guys, or should i just go ahead and bring it to the shop, the only reason why i didnt bring it to the shop is because they may try to tell me to replaces my wires and spark plugs but there fairly new and i dont want that, just the seals and thats it. help me out guys!
Old Nov 20, 2004 | 09:57 AM
dr_latino999's Avatar
Default Re: still leaking??? (DrewQ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewQ1 &raquo;</TD></TR><TR><TD CLASS="quote">I replaced my valve cover gasket and spark plug tube seals and I still ended up having oil in my sparkplugs and i see light residue of oil around the valve cover. why is that, i belive i tightend the studs as tight as possible but i was also told you dont want to tighten it to much or you can snap the studs, do i need to just tighten them just a little nudge more or what help me out guys, or should i just go ahead and bring it to the shop, the only reason why i didnt bring it to the shop is because they may try to tell me to replaces my wires and spark plugs but there fairly new and i dont want that, just the seals and thats it. help me out guys!</TD></TR></TABLE>
You should only tighten the valve cover bolts (On a SOHC) to about 7ft. lbs, any more and you risk breaking the stud or the crown nut, which I have done many a time. If you still have oil on the spark plug, you may have a valve seal leakage issue, a problem that has plagued a couple of my older motors; and last, did you wipe off the valve cover and the head around the gasket after you installed the new gasket?
Old Nov 20, 2004 | 02:35 PM
drdisco69's Avatar
Default Re: still leaking??? (dr_latino999)
PCV problems? Excessive blowby?
Old Nov 20, 2004 | 03:07 PM
eda6's Avatar
If you didn't clean the oil off the head when you put the new gasket on it will leak.
Torque to 7 ft.lbs. 7 lbs=as tight as you can get them with your hand. I use a 10mm socket on a 6" extension. Too tight and you'll ruin the valve cover grommets.
I don't recall d-series valve cover gasket but the b-series valve cover gaskets have a "wider" part in the middle of the gasket on the intake side. I wasn't paying attention to this and put it on backwards. Check that.
Old Nov 21, 2004 | 03:06 PM
DrewQ1's Avatar
yeah i cleaned it off, i'll try to do it one more time if not i'll bring it to the shop, is there anything else i need to add to the gaskets before i put it on.
Old Nov 21, 2004 | 10:36 PM
DrewQ1's Avatar
anyone?
b16bri
Mar 9, 2008 09:30 AM
88CRX-CRB-UT
Aug 1, 2007 06:09 AM
CalhounBoi
Oct 1, 2006 05:25 PM
xintegr
Mar 18, 2005 08:00 AM
Civic
May 8, 2003 08:09 AM
