steering column
Old May 27, 2003 | 03:48 AM
kliph's Avatar
Default steering column
ok....my jeep has a major steering column problem. im in my car cleaning it (car is off, not moving) and i was messing the the steering wheel and it moves...alot. I put it in a different position (adj. wheel) and it still moves...its bad enuf that when i drive it its kinda scary cuz its so shaky (not my alighnment) im thinking its something that is loose and just needs to be adjeusted but im not sure...if u can help thank you Cliff
Old May 27, 2003 | 09:21 AM
JimBlake's Avatar
Default Re: steering column (kliph)
Start by taking off whatever covers you can so you can see the shaft that spins with the steering wheel. Then (with car turned off) rock the wheel back & forth while you look for where the loose joint is.
I don't know Jeeps, but (I think) ALL steering columns have U-joints in them. They get loose. You gotta find out whether you can buy just the U-joints or maybe the whole intermediate shaft or whatever...
Old May 27, 2003 | 09:42 AM
Nextelbuddy's Avatar
Default Re: steering column (JimBlake)
u could check whgere the steering column meets the steering rack and see if thats loose
steadysupreme
Mar 23, 2008 01:04 PM
breanna
Feb 28, 2006 12:51 AM
choi830
Oct 30, 2003 05:13 AM
