loose steering
Old Oct 30, 2003 | 05:01 AM
choi830's Avatar
Default loose steering
Hi, all
The steering wheel is getting loose on my GSR. I checked the service manual and found a section on adjusting the steering rack guide screw. Do you think this adjustment will make the steering wheel tighter?
Thanks a lot
Andy
Old Oct 30, 2003 | 05:13 AM
JimBlake's Avatar
Default Re: loose steering (choi830)
It all depends on HOW it's getting loose.
The rack guide screw holds the steering pinion tight against the rack. Don't just keep tightening if the PROPER setting doesn't help your problem.
If YOUR steering wheel is coming loose from the steering column, then you need to look in the section about removing & installing the wheel. There's u-joints & clamps in the steering column between the steering wheel & the rack. Find WHERE the looseness is located first.
1lowsol2
Oct 3, 2006 03:37 PM
breanna
Feb 28, 2006 12:51 AM
tianporn
Jun 16, 2004 08:25 PM
kliph
May 27, 2003 09:42 AM
