Steel braided brake lines ??
Old Jul 1, 2002 | 09:30 PM
Roger's Avatar
Default Steel braided brake lines ??
Im currantly doing a drum to disc conversion on my 94 EG6 civic h/b. So far I have the following: rear brake conversion with e-brake cables off a 97 japense spec integra. I'm getting ready to buy some steel braided brake lines but the shop that has them in stock only have rear ABS lines. My question is: will these ABS brake lines work on my brake system for my car with the rear conversion from drum to disc.?? Whats the difference between ABS and non-ABS brake lines ?? Are the brackets different? Any information will help tremendously. Thx.
Old Jul 2, 2002 | 05:07 AM
GSpeedR's Avatar
Default Re: Steel braided brake lines ?? (Roger)
Steel braided brake lines are probably similar enough to steel braided ABS lines. I doubt the inner line diameter would change.
However, the lengths of each are not the same. If they are too short (ABS) then you can't use them. Too long, and you have to do some heavy rerouting.
hachilovr
Nov 8, 2017 10:12 AM
hondmywrld
Mar 19, 2008 11:47 PM
EL-Driver
Feb 5, 2002 05:18 PM
