Starting problems with a '97 Honda CB 500S
Old Oct 13, 2008 | 06:04 AM
knocar's Avatar
Default Starting problems with a '97 Honda CB 500S
Bike refuses to start. Starter motor turns over a couple of times but doesn't catch. Its pretty laboured and after a few turns will not turn over at all. Then you only have the sound of the relay clicking.
Initially I thought it was a cold weather problem as it took a couple of goes to start if it was cold/wet. Then it just generally wouldn't start, even on warm sunny days. So I tried a few things : Battery is fairly new, and was showing the correct voltage. The starter relay was working fine and clicking every time I pressed the starter switch. The starter fuse was fine. I changed the starter motor for a spare I had (Actually the original one). This was worse (more laboured and less turns) so I'm planning to switch it back, although I don't think this will cure the problem.
Failing a miracle cure, if anyone could point me in the direction of an online Honda or CB 500 forum, that works for me too.
Old Oct 13, 2008 | 06:30 AM
Nosk's Avatar
Default Re: Starting problems with a '97 Honda CB 500S (knocar)
Try charging the battery, if that's not it, check the cable between the starter relay and the starter.
_______________________
http://www.partstrain.com
Derrick Carr
Honda CR-V & Element
Jan 24, 2018 06:30 AM
Hanmin
May 2, 2010 05:01 PM
5spdIntegra
Mar 26, 2004 12:54 PM
junya16
Feb 26, 2003 08:31 AM
