starter problems!!!!!!!!!!!!!!!!
Old Aug 13, 2003 | 09:09 AM
crx1856's Avatar
Default starter problems!!!!!!!!!!!!!!!!
after trying to start my car numerous times, the starter just stopped turning. i checked it and it was really hot. the plug in wire melted through to the wire and touched the starter bolt which may have been the problem. i took it down to kragen and it tested ok but it still wont turn when i turn the ignition. i checked all the fuses and they are all fine. anyone know what the problem could be????
Old Aug 18, 2003 | 09:58 PM
scdarksol's Avatar
Default Re: starter problems!!!!!!!!!!!!!!!! (crx1856)
I took, my starter to pep boys and it tested good, (it was bad), and I got a new one car started right up!
Old Aug 18, 2003 | 10:16 PM
sporkcrx's Avatar
Default Re: starter problems!!!!!!!!!!!!!!!! (scdarksol)
Mine just went out in the rex. It would make a single click, and after a few tries it would start up. Then one night it refused to start. I could hear the starter do a single click when the key was turned, but nothing more. Push started the car, put in a new starter the next day and it's fine.
Old Aug 20, 2003 | 10:13 PM
MrIllegalX's Avatar
FYI....if you think your starter is out, try cranking it and hit it with a hammer hard. If it starts up then your starter needs to be replaced. If it doesn't then the starter isn't getting the power. Honestly, I've seen respectable mechanics do this to test it.
Old Aug 20, 2003 | 10:24 PM
HiroHatch's Avatar
Default Re: (MrIllegalX)
sound respectiable to me hehehe
Jack Murphy
Jun 21, 2017 06:23 PM
uniquerider
Aug 12, 2015 11:00 PM
JPerkMr954
Jun 9, 2013 08:51 PM
battleREADYb20
Apr 30, 2009 02:36 AM
elpermgrande
Aug 9, 2002 06:43 AM
