Standalone on LS/VTEC, where to put the knock sensor.
Old Mar 13, 2003 | 01:48 PM
Mr.Saturn's Avatar
Default Standalone on LS/VTEC, where to put the knock sensor.
I was wondering where I should put a knock sensor on the B18B block for the standalone for tuning purposes. Pics are a great help and not that old "alternator bracket" one. I want an actual decent location that works like it should. Also looking for responses from people who actually have done a similar job and not just guessing because I don't want to tap into oil lines or anything else important.
Old Mar 13, 2003 | 04:40 PM
Mr.Saturn's Avatar
Default Re: Standalone on LS/VTEC, where to put the knock sensor. (Mr.Saturn)
ttt cmon someone has to know
Old Mar 13, 2003 | 07:39 PM
Mr.Saturn's Avatar
ttt again
Old Mar 13, 2003 | 10:49 PM
tnbigdawg's Avatar
I drilled and tapped into the block for my KS. There was a spot on the block for this.
Old Mar 14, 2003 | 01:38 AM
Mr.Saturn's Avatar
Default Re: Standalone on LS/VTEC, where to put the knock sensor. (tnbigdawg)
do you have ne pics?
Old Mar 14, 2003 | 03:57 AM
turbodav's Avatar
i mounted mine on the right side alternator barket bolt here is a pic.
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
here is another pic.
the finish picture
Old Mar 14, 2003 | 09:45 AM
Mr.Saturn's Avatar
That place is ok for getting a stock ecu to work just enough to run the engine, but for getting an accurate knock reading for tuning, I know you have to be against a cylinder, I have heard the #3 is where to go but I am not sure where to tap without hitting any oil passages.
Old Mar 14, 2003 | 11:10 AM
tnbigdawg's Avatar
no I aint got any pics. if you got a picture of a LS block then I can point it out for you.
Old Mar 15, 2003 | 02:59 AM
Mr.Saturn's Avatar
Default Re: Standalone on LS/VTEC, where to put the knock sensor. (turbodav)
hes got a pretty good one there
Old Mar 15, 2003 | 11:01 AM
tnbigdawg's Avatar
I believe thats where I put mine. Just dont drill too deep, and use washers so that the knock sensor is firmly bolted in.
Old Mar 15, 2003 | 12:04 PM
Mr.Saturn's Avatar
Thanks thats a great help!
KURUPTinc
Jun 22, 2005 11:03 PM
SSS2000
Aug 26, 2004 01:45 PM
Universal Magnetic
Oct 22, 2003 11:44 PM
black-hatch
Jan 5, 2003 01:17 PM
tysir
Aug 27, 2001 09:26 PM
