Putting knock sensor on B18A block.
Old Aug 26, 2004 | 05:35 AM
SSS2000's Avatar
Default Putting knock sensor on B18A block.
I have read to drill and then tap the hole for the K/S where the alternator bracket is located on the back of the block. Can this be done w/o removing the intake manifold, or are there any other locations where a knock sensor can be added to the block that are easier to access and work just as well.
Becasue I have a B18B head the spot where the breather chamber taps into the back of the block isn't used. Could the K/S go here?
Thanks for any feedback.
Tim
Old Aug 26, 2004 | 09:17 AM
turbohondask's Avatar
Default Re: Putting knock sensor on B18A block. (MilanoRedLST)
get a 17 mm nut from a honda, and test if it fits onto the knock sensor, then take the alternor bolt out and get it welded together, I did it on a car and has not ran a code yet. (5 months)
Old Aug 26, 2004 | 09:31 AM
Shu's Avatar
Shu
Default Re: Putting knock sensor on B18A block. (turbohondask)
Weld a nut to the end of a bolt and put it in the hole at the upper corner of the head above the alternator. The hole the helms specifies to use to attach a lift chain to.
Old Aug 26, 2004 | 01:45 PM
SSS2000's Avatar
Default Re: Putting knock sensor on B18A block. (Shu)
Great info!
Thanks for the help.
eddisgetti1
Nov 12, 2011 09:45 PM
davidu
10
Jul 27, 2008 11:01 AM
slowteg550
Jun 27, 2006 04:35 PM
abbas
May 2, 2005 02:23 PM
black-hatch
Jan 5, 2003 01:17 PM
