Squeaking Noise over speed bumps
Everytime I go over a speed bump, my front end makes this squeaky/rubbery sound... it bugs the hell out of me. My friend that owns a shop says its my "Cheap Progress Camber Kit". Is it the camber kit or could it be my springs because they're just perched directly on the strut(I'm not sure if there should be anything between the strut and the spring).
HT White Ops
Re: Squeaking Noise over speed bumps (Maverick77)
I lubed them up when I put them on.. Do you think I have to lube it more? Will I have to get alignment again?
So, yes, you will have to grease your poly from time-to-time as the lube washes out. Use some good waterproof grease and rough-up the bushings next time. That will keep them quiet longer.
Re: Squeaking Noise over speed bumps (BlackDeuceCoupe)
Its so dumb that the bushings for the Progress kit are yellow. Can you recommend some waterproof grease? What do you mean by rough up the bushings, do you mean sand them down?
SpoonsportsEH2: Yah, I think its the camber kit... I've heard Ingalls is the best. If I were you, I'd sell that one and get the Ingalls kit
WildPig
Suspension & Brakes
63
10-27-2005 12:05 PM
