sputtering, bogging at 8k and over
Old Jul 8, 2003 | 04:37 AM
torr's Avatar
Default sputtering, bogging at 8k and over
ls motor bogs and sputters only at full throttle and at around 8k rpms. any ideas
fuel pump?
plugs were good
oh, and when i'm driving at around 70mph and i down shift to 3rd and punch it. the car doesn't react like it should. it doesn't take off like it use to. any ideas
Old Jul 8, 2003 | 06:21 AM
trbob16a's Avatar
Default Re: sputtering, bogging at 8k and over (torr)
is this an ls/vtec or something? what is the rest of the setup?
although I don't remember exactly what the rev limit is, a stock ls would be bouncing off it by then
Old Jul 8, 2003 | 07:52 AM
torr's Avatar
Default Re: sputtering, bogging at 8k and over (trbob16a)
yep, ls/vtec- chipped p28, programmed for 52k vtec and 92k redline
Old Jul 8, 2003 | 09:00 AM
raene's Avatar
Is it bogging or is it detonating? If it's detonating at the high end you'll feel it as a loss of power. You might not hear it.
This is the voice of experience, BTW . 19 degrees timing (4 degrees advanced) on 94 octane, and it was a-pingin'
Old Jul 8, 2003 | 04:01 PM
torr's Avatar
Default Re: sputtering, bogging at 8k and over (raene)
i don't think it's detonating, but then again i wouldn't recognize detonation if it slapped me in the face.
what causes detonation, how does it sound.
the car just bogs and sputters at 8k rpm or so. sometimes it does it and sometimes it doesn't
Old Jul 8, 2003 | 04:30 PM
machine4321's Avatar
i would start with re grounding your motor to the chasie(sp)
it sounds like a ignition problem.....mabye
Old Jul 8, 2003 | 04:44 PM
bigTom's Avatar
Default Re: (machine4321)
what kind of program is it? i personally do not like "chipped" computers... people buy these chips with programs on them that advance ur timing... bump vtec engagement a little higher and change the fuel maps around and they make everyone think there motors are running better than ever when in reality u might be leaning the crap out of it and might not even know it...
Old Jul 9, 2003 | 04:24 AM
torr's Avatar
Default Re: (ek9t)
it's a skunk2 program. you could be definetly correct about the program
Old Jul 9, 2003 | 05:20 AM
sslude's Avatar
detontaion happens when your fuel is burned, not by spark plugs, but heat on cylinder walls, piston, ect..
Old Jul 9, 2003 | 07:37 AM
raene's Avatar
Default Re: sputtering, bogging at 8k and over (sslude)
You mean when fuel is ignited prior to the spark being fired... and that's not entirely true... you can have detonation by advancing the spark too much, so the fuel's not preigniting but the flame front from the ignition of the mixture reaches the piston before it's gotten to TDC.
Pinging isn't always preignition, but it can be caused by preignition.
B16'D DA9
20
Jul 10, 2005 09:42 AM
turbotypeR@SPEC
Jun 7, 2003 11:23 AM
wm5holla
Jan 14, 2003 04:40 AM
