Spoon Stroker For B16B
Old Dec 16, 2004 | 10:13 PM
  #26
bossman032's Avatar
Default Re: Spoon Stroker For B16B (r2ck_p)
some fucken people don't understand.
itr crank is not cheap around 700buck alone.
RODS
Pistons
Rings
get a fucken clue before u start to talk. why buy used crank 150 and another 150 for balance. then spend another 200 in rods then pistons another 170ish rings etc
spoon is an excellent kit you cant beat it
Old Dec 16, 2004 | 11:46 PM
  #27
r2ck_p's Avatar
Default Re: Spoon Stroker For B16B (bossman032)
Right guys, I have also research the Jun Stroker last night but its alot more expensive, probabiliy as they don't use stock honda items. The price is $5,543.
This will take it to a 2.0Litre but will also require a boring to 82mm.
I can either go with,
1. Spoon Stroker, ECU and then Jun 3 Cams, Springs, Retainers, Cam Gears
2. Jun Stroker, ECU, Cam Gears (to see if I can get more out of stock cams)
My only worry at first was is it safe to bore to 82mm and also is it safe to use a 2.0litre stroker? I know Jun products are of superb quality as I currently have a Jun Exhaust Manifold. Has anyone used this stroker before and if so what did you think? Will it give me alot more over my stock 1.6 setup?
Thanks.
Modified by r2ck_p at 9:14 AM 12/17/2004
Old Dec 17, 2004 | 05:46 AM
  #28
WAFFLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">some fucken people don't understand.
RODS
Pistons
Rings
spoon is an excellent kit you cant beat it </TD></TR></TABLE>
Have you ever had anything balanced before. I'm telling you, your machine shop will NOT be able to make the crank any more balanced, same goes with the pistons. I've done this too many times.
Old Dec 17, 2004 | 09:13 AM
  #29
bossman032's Avatar
Default Re: Spoon Stroker For B16B (WAFFLES)
why would new parts need balance?
when they come balanced.
Old Dec 17, 2004 | 09:16 AM
  #30
bossman032's Avatar
Option 1 Look good enough.
You will have a bigger bottom end and some head work cams tunning will get you some major hp. Most people when they go Big they upgrade the 16b bottom end. I was going to do the same thing and keep my ctr pistons then I found out K20 soo
blah
Old Dec 17, 2004 | 09:25 AM
  #31
WAFFLES's Avatar
BRAND NEW OEM PARTS, ASWELL AS USED OEM PARTS. IS THAT HARD TO UNDERSTAND?
My USED LS crank was 100% perfectly balanced before I took it to my machine shop. So unless yours or the one you are buying is damaged, there is no need to buy a brand new crankshaft. Same goes for the pistons. Jesus, is it that hard for you guys to understand?
YOU DON'T NEED TO BUY BRAND NEW PARTS UNLESS YOURS ARE DAMAGED. Take a used set of pistons and rods to be balanced, find out yourself. The rods are the only thing I have ever seen that need to be balanced, and they were barely off.
Old Dec 17, 2004 | 09:29 AM
  #32
bossman032's Avatar
lol
I would never buy used parts maybe your pefereance is used parts.
for 1000 I wouldn't mind getting the spoon kit. Its worth every penny.
Old Dec 17, 2004 | 10:29 AM
  #33
Kataku2K3's Avatar
WAFFLES
bossman, are USED OE parts that bad...?
Old Dec 17, 2004 | 10:36 AM
  #34
bossman032's Avatar
Default Re: Spoon Stroker For B16B (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">WAFFLES
bossman, are USED OE parts that bad...? </TD></TR></TABLE>
if they aren't used I would eat them
no need to balance/throw them away if they are new right
I don't see the reason to buy used parts maybe they are cheaper I guess how cheaper are they you gotta ask
Old Dec 19, 2004 | 02:21 PM
  #35
vteczone's Avatar
bossman..you would never know if spoon actually took the crank for their stroker kit off a USED ITR.. for $1000,i would rather buy scat or crower crank which they made themself and not oem honda. im not saying spoon isnt good,im saying u r paying too much for just their name.
Old Dec 21, 2004 | 04:19 AM
  #36
r2ck_p's Avatar
Default Re: (vteczone)
Anyone, IS IT SAFE TO BORE TO 82mm, IS THIS OUTSIDE OF HONDA TOLERANCES???
Thanks.
Old Dec 21, 2004 | 06:55 AM
  #37
vteczone's Avatar
well so far 82mm is the recommended max bore on stock sleeve..any higher your engine wouldnt last long...
aeros
10
Aug 30, 2011 05:05 AM
highrevnef
Apr 3, 2005 09:21 PM
ar2d2
Oct 23, 2004 09:40 AM
PYITR821
Jun 9, 2004 11:30 PM
ek9lau
May 28, 2003 11:59 PM
