Spoon spec ECU opinions
Old Oct 28, 2007 | 04:04 PM
JustG's Avatar
Default Spoon spec ECU opinions
Found a CPU in my area with the following specs:
VTEC @4400
NO KNOCK SENSOR
REDLINE 9300
UPGRADED TIMING
SPOON SPEC FUEL AND AIR MAPPING.
Its used on a GSR, so my question is, will it work for a B16A2 effectivly without having to re-tune it?
Right now I have a 97 coupe with a 2000 SIR swap with all the SIR components. Motor, tranny, ecu... Cold air intake and Integra stock (I think) exhaust. I just bought this car on friday and plan to progressivly build it.
Also, VTEC hits @ ~5500 rpm and rev limiter is ~7500.
Thanks for all/any input
Old Oct 28, 2007 | 05:23 PM
mtber's Avatar
Default Re: Spoon spec ECU opinions (JustG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustG &raquo;</TD></TR><TR><TD CLASS="quote">Found a CPU in my area with the following specs:
VTEC @4400
NO KNOCK SENSOR
REDLINE 9300
UPGRADED TIMING
Engaging vtec at 4400 rpms isn't going to make any power, it will cause a dip in your powerband.
Put your car on a dyno and you will see you have a nice dip at 4400 rpms to around 5000 rpms using that ecu. You will also notice the a/f ratios will be rich as can be.
Get your self an ecu with a base program specifically for your motor.
Old Oct 28, 2007 | 06:43 PM
JustG's Avatar
Default Re: Spoon spec ECU opinions (mtber)
Thanks! I am trying my hardest to not "jump-the gun" with this car. Like I said, I just got it on friday and dont even have it plated yet.
This ECU is available @ a decent price and thought that if it would be useful to me, I would buy it now for use later.
First thing I think I will do is get a dyno pull to see where I'm @ and devise a "plan-of-attack" from there.
Thanks again!
TheAccordGuy
May 18, 2006 04:56 PM
BillB
Jan 6, 2005 02:46 PM
ITR#465
Aug 13, 2004 03:13 AM
zivvy
Jan 7, 2003 03:55 PM
chigsu
Dec 27, 2002 10:29 PM
