Speedometer not working??
Old Feb 9, 2004 | 04:34 AM
stumbler's Avatar
Default Speedometer not working??
last night i changed my trans fluid and now my speedo isn't working. i got home and double checked... and the vss harness was plugged in. however, i unplugged it and plugged it back in.
is there something else that could cause this? is it possible to not put the vss itself into the trans correctly? any help is appreciated.
thank you
Old Feb 9, 2004 | 09:45 AM
stumbler's Avatar
Default Re: Speedometer not working?? (stumbler)
does the gear line up somehow in there? will it not go in if the gear isn't lined up?
this would probably be the reason for my cel light as well huh?
i also soldered my a/f guage in yesterday, but i had it hooked up, just not soldered before and my speedo worked fine. think that could have messes with anything?
Modified by stumbler at 7:18 PM 2/9/2004
Modified by stumbler at 7:34 PM 2/9/2004
Old Feb 9, 2004 | 09:51 AM
mmuller's Avatar
Mad Scientist
well, its obviously something to do with the vss, recheck the connections and make sure the sensor is all the way in the tranny; it kinda clicks into place
Modified by mmuller at 3:01 AM 2/10/2004
Old Feb 9, 2004 | 06:01 PM
scrambledeg's Avatar
I had a similar problem and foud out it was in the plug it self was the problem.
One of the pins were broke and missing check that see if that helps.
Old Feb 10, 2004 | 08:53 AM
stumbler's Avatar
Default Re: Speedometer not working?? (scrambledeg)
thank you... will do
Old Feb 10, 2004 | 12:34 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumbler &raquo;</TD></TR><TR><TD CLASS="quote">thank you... will do</TD></TR></TABLE>
come back and let us know
Old Feb 12, 2004 | 03:54 AM
stumbler's Avatar
Default Re: Speedometer not working?? (USDMDC2)
haven't fixed it yet, that is coming up this weekend. just noticed today that vtec is not engaging. is this normal for when the speedo isn't working?
Old Feb 12, 2004 | 05:57 AM
Mista Bone's Avatar
D Tranny Guru
99% of speedo issues are VSS connector related
Old Feb 12, 2004 | 07:10 AM
stumbler's Avatar
anyone know about the vtec issue i mentioned above?
Old Feb 12, 2004 | 09:05 AM
torr's Avatar
the vtec will not work because your speedo's broke. i think the ecu cant read it so it doesn't think that your car is actually going anywhere.
check your
vss fuse
ground on the tranny
Old Feb 12, 2004 | 10:27 AM
stumbler's Avatar
Default Re: Speedometer not working?? (torr)
thank you
Old Feb 13, 2004 | 04:52 PM
mugenEK's Avatar
yep check the fuse man
Old Feb 13, 2004 | 10:28 PM
mmuller's Avatar
Mad Scientist
Default Re: Speedometer not working?? (mugenEK)
check #24 fuse
check connector:
black=ground
bl/yell= battery power (ignition on)
orange= 5v (ig on)
When you took out the sensor, did you only take the vss out as a whole or did it come apart?If it came apart maybe you didnt put the drive link in the right position
Old Feb 14, 2004 | 02:49 PM
stumbler's Avatar
Default Re: Speedometer not working?? (mmuller)
where is #24 fuse?
Old Feb 14, 2004 | 02:50 PM
stumbler's Avatar
how do i ensure that the drive link is in the right position?
Old Feb 14, 2004 | 03:23 PM
stumbler's Avatar
also, the day i changed my trans fluid, i installed an af guage. i dont have a dmm right now, but i did check the conector and cleaned out the electrical connection. still confused as to why this isnt working. hopefully tomorrow i can check the voltages.
where is #24 fuse?
Old Feb 14, 2004 | 06:49 PM
torr's Avatar
also check your wiring when you installed your guage, if i remember right there's a wire that goes from the a/f guage to the o2 wire. check that wire for any shorts to ground, that o2 wire will also through your speedo out of whack.
the fuse your looking for is in your fuse box inside of the car under the dash. it's the fourth one (i think) from the right in the second row. i think it's a 7.5 amp fuse. i would go check in my car but it's to cold outside.
Old Feb 16, 2004 | 05:18 AM
stumbler's Avatar
witht he a/f guage, i had it installed prior to the day, but on that day i actually soldered it.i guess i could unhook it to be sure. anyone able to verify the fuse location?
Old Feb 17, 2004 | 05:37 AM
stumbler's Avatar
bump
i disconnected the a/f guage and checked all the underdash fuses and the speedo is still not working.
if i were to check the voltages running into the vss and they were/ one wqas off, what would i do to fix thatr.
also, i checked all the pins on the vss and none of them were broken or bent.
anyone have any other ideas?
Old Feb 17, 2004 | 10:11 AM
stumbler's Avatar
anyone... any ideas?
Old Feb 18, 2004 | 04:37 AM
stumbler's Avatar
Default Re: (stumbler)
bump... anyone?
Old Feb 18, 2004 | 10:46 AM
stumbler's Avatar
ttt
Old Feb 18, 2004 | 10:54 AM
MightyMouseTech's Avatar
So why did you have the VSS out to change tranny fluid in the first place?
Old Feb 18, 2004 | 11:29 AM
stumbler's Avatar
Default Re: (MightyMouseTech)
to get the new fluid in. i dont have one of those bent tube to pump it into the filler hole, and it is tough to tilt my car on the side to fill in through the fill hole
Old Feb 18, 2004 | 02:15 PM
Actually, putting your car on the side is the WRONG way to do it, depending on which way you lean the car, the tranny will be very under or over filled.
The best way to fill it through the fill hole is to use a long funnel with a 90 degree bend at the bottom. (like a copper elbow) This allows you to fill it from up above while having the car level so that it is at the proper level.
I have yet to try a suction pump that doesn't make a big mess of everything, and I REALLY hate getting oil on my shop floor.
