Speedo works when it wants too
Old Aug 20, 2011 | 08:10 PM
yungmulacrx's Avatar
Default Speedo works when it wants too
94 accord ex with h22 euro r swap.. Speedo works when it wants too.. I have tested the voltage at the vss plug and have a full 12 volts, I have checked the continuity for the wire that goes to the ecu which was .6 ohms. I have gotten a cel code for the vss so i replace it with a new one and still problem exists.. Since i have changed the vss i have not gotten a code yet but it has only been 2 days.. Have also used dielectric grease on the plug. I have read about the speedo circuit board could be bad but would that throw the vss code or work sometimes.. Odometer only works when the speedo is working. I have two ecus for the car and both do the same. Any input would be helpful.. Thank You
Old Aug 20, 2011 | 08:15 PM
rickyracer's Avatar
Default Re: Speedo works when it wants too
i had that problem one time and it was the plug that goes into the speed sensor. i went to a local junk yard and got another plug, installed it and never had a problem again.
Old Aug 20, 2011 | 08:19 PM
The new vss i got has no pigtail plug.. The plug is built into the vss so i dont know.. Ive been thinking about taking the car to my dads shop and putting in on the lift while in gear and messing with the plug and wires to see if it comes on goes off ect..
Old Aug 21, 2011 | 07:53 AM
mouab18c1's Avatar
Check for corrosion on the VSS plug
Jesse_Boyer
12
Dec 24, 2024 02:21 AM
092eg6
10
Oct 29, 2010 08:49 AM
KILLAB17VTEC
Dec 2, 2009 10:31 PM
justinxecushyn
Feb 14, 2006 08:09 AM
scUba-stEve
Jan 23, 2005 07:25 PM
