Speedo Problems
Old Dec 1, 2005 | 07:54 PM
EMwUnDuH's Avatar
Default Speedo Problems
Hey guys what do you think. My speedo isnt working, and I know for sure its not the cluster or vss. Had a bad ground in my obd2-1 conversion harness, but i changed that and it still didnt work. Should I just change out the whole harness or what???
Help!!!!!!!!1111!!!
Old Dec 2, 2005 | 08:38 AM
EMwUnDuH's Avatar
TTT
Old Dec 2, 2005 | 11:14 AM
djtony5's Avatar
It could be your VSS (Vehicle speed sensor) located on top of the transmission. Try replacing that and there you go.
Old Dec 2, 2005 | 10:48 PM
EMwUnDuH's Avatar
I already checked that
Old Dec 3, 2005 | 07:12 AM
h22 civic's Avatar
Default Re: (cockchaos)
any codes being thrown?
Old Dec 3, 2005 | 07:23 AM
EMwUnDuH's Avatar
Yep, it goes into limp mode. But the code says it is the vss, but it isn't. I am thinking it is something in the obd2-1 conversion harness
Old Dec 3, 2005 | 08:09 AM
h22 civic's Avatar
possibly do a alternator check also make sure it aint weal voltage out put and causing weird non true codes start car and pull battery see if it still runs
bobmwn
Jan 8, 2010 10:51 PM
SlowSOHC-T
24
Feb 26, 2006 03:25 PM
dfn_doe
18
Jan 13, 2006 12:00 PM
sleepyEK
Oct 17, 2005 09:08 PM
BBY98EX
Feb 18, 2005 04:40 PM
