specs for engine buildup
I know there is probably this question out there but i don't have time to look for the answer. I want to build an engine, but don't want to buy the wrong thing/or buy to much. what i mean is i don't want to waste money on un necessary parts for my engine build. i want to build a turbo engine with about 300-350 hp w/turbo @ 8psi.
here is what i have so far:
* 91' b16a stock head.
* 94' b18b engine swap.
* 92' DX hb black.
these are the part i have considered:
**Block**
*b18b block
*srp pistons(10:1)/ new rings
*block gaurd
*stock rods/pins
*vtec oil pump
*vtec water pump
*vtec timing belt
*lsvtec machine tamp for oil/dual pins
**head**
*valves
*retainers
*dual springs
*ls head gasket
**trans**
*stage 3 clutch
*stock axles
if i missed anything please let me know any other sugestions would be helpfull. i don't want to waste money on thing that are not really needed let resleeving the block if it really is not something that i don't need to do for the amount of hp. i want to have.
oh yeah i plan to use the fmax turbo kit or the revhard kit on setup.
* 92' DX hb black.
**Block**
*b18b block
*block gaurd
*stock rods/pins
*vtec oil pump
*vtec water pump
*vtec timing belt
**head**
*valves
*retainers
*dual springs
*ls head gasket
**trans**
*stage 3 clutch
*stock axles
stinner.5
Jan 24, 2013 11:29 AM
Blue CRX
Oct 27, 2004 04:28 PM
