some CAM (TDC) help please
Old Aug 26, 2004 | 06:57 AM
quis23's Avatar
Default some CAM (TDC) help please
motor --DOHC ZC , cams are stock.
ok here goes-- i installed a new headgasket and now i can't get my cams to seat properly. the crank is at TDC, but when i put the cams in at TDC the lobs sit on the
rockers. when i get the cams to sit then they are not at TDC. do i need to just simply adjust my valves or push down the rockers or something?
someone help me before i go crazy!!
cam seated all the way= not at TDC
cams at TDC=
Old Aug 26, 2004 | 08:09 AM
JDMotive's Avatar
Default Re: some CAM (TDC) help please (quis23)
Put all of the cam caps on and tighten them all of the way.Some of the cam lobes will be pushing on the rockers when aligned at tdc.
Old Aug 26, 2004 | 08:21 AM
quis23's Avatar
Default Re: some CAM (JDMotive)
thats what i was thinking,but i was afraid i would bend some valves.
Old Aug 26, 2004 | 08:51 AM
JimBlake's Avatar
Default Re: some CAM (quis23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quis23 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was thinking,but i was afraid i would bend some valves. </TD></TR></TABLE>Then put your crank 90deg. away from TDC. Now all the pistons are mid-stroke, so nothing can hit. You can do whatever you want with the camshaft.
When you have the camshaft sitting at TDC, then move the crank directly back to TDC.
Old Aug 26, 2004 | 08:54 AM
JDMotive's Avatar
When the crank is at tdc the #1 and #4 piston will be at the top of the cylinders.The lobes for #1 and #4 cylinder shouldnt be pushing the valves down.#2 and 3 will be at bottom dead center,so the lobes for those should be pushing the valves a little.You will have no clearance issues or valve contact.Make sure the line on the sides of each cam gear are even and lined up with each other.The "UP" doesnt have to be 100% straight up,as long as the marks are even.
Old Aug 26, 2004 | 09:07 AM
quis23's Avatar
thanks guys
Old Aug 26, 2004 | 09:59 AM
metalgears's Avatar
haha..I am having the same exact problem as you after i did my cam swap.
The intake cam on my h22 looks exactly like that but my exhaust cam looks ok (straight up)
Let me know if how you fixed it
EF'GSRrr91
12
Sep 18, 2014 06:59 AM
threehonda
K Series
Dec 20, 2009 06:37 PM
HFP_racing
11
May 12, 2009 06:12 PM
